3500 exhuast manifolds on 3400
  • Rootie524
    • Feb 2010
    • 543
    I'm looking into getting 3500 exhaust manifolds for my 3400 to hold me over till i get headers.
    are the benefits going from the 3400 - 3500 manis noticeable? is it worth it?
    i've also heard that the way the rear 3500 mani is designed, it is more beneficial to use 2 front manis. is that necessary? is the difference that great to justify 2 fronts?
    let me know what you guys think. thanks
  • Rootie524
    • Feb 2010
    • 543
    bumpski
      it depends on how your engine bay is set up, if you can run a front and a rear then go for it. The few people that have used them had tight bays so the 2 fronts worked out best.
      the good 3500 manifolds flow a ton more than the 3x00 logs.
      • Rootie524
        • Feb 2010
        • 543
        how would i even set that up with two fronts? because the 3500 front on a 3400 wouldnt be able to use the crossover because the front mani put the exhaust down and not the the right side to connect to the back.
        i imagine custom work would be in order?
          just a pair of flanges, some mandrel 2" J bends from Summit and some random scrap pipe.
          V6bluebird (Damon) dropped off his 3500 front manifolds and the flanges that Forced_Firebird sold him. I started to toss together a crossover pipe out of left over mandrel bends tonight. the flanges has a 2.25" port which is too large so after the 1st bend i reduced the pipe size to 2" which...
          • RedBird
            Aka Mr. 5th Motor
            • Sep 2006
            • 426
            yeah, the stock 3500 rear points almost directly straight back so most applications for custom fits need 2 fronts.
            the setup works great, BUT if you go that way, put a flex pipe near the flanges if you can. i havent had any issues with the front pipe setup but the rear one has a nasty crack in it because it couldn't flex enough. took a year to crack but it eventually did.
            also in a j-body with no A/C lines it clears the rack by <.5" but with the rack heat shield from a quad grand am everything is peachy.
            Cammed 3400 --> 224whp 210wtq
            Cammed 3500 --> ???
            1 of 5 3500 J-Bodies
