First outing with the WOT heads and cam
  • asylummotorsports
    Banned
    • Oct 2005
    • 649
    Great Lakes Dragway (WI) during BerettaFest.
    13.75 @ 102.57
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    What was your 60ft? I'd say by your trap speed that you could get down to a 13.4ish
    Grats
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • asylummotorsports
      Banned
      • Oct 2005
      • 649
      1.87 @ 60' on the best run.
      Most were 1.90's
      That was the first time out after an 11 hour "break-in" drive to Chicago, then and hour and a half to Wisconsin to Great Lakes dragway.
      There is more there I'm sure with some tuning.
        Live life 3.7mi at a time
        • 4555
        Grats
        For sure. Loner's car was at 13.1 with those trap speeds (and 2.0 60')
        Nice job assylum
        • RedBird
          Aka Mr. 5th Motor
          • Sep 2006
          • 426
          dead even with my times, plus 2mph. Nice!
          Cam specs?
          Cammed 3400 --> 224whp 210wtq
          Cammed 3500 --> ???
          1 of 5 3500 J-Bodies
            low 13's for sure. My 108's and 109's should have put me in the high 12's
            are you manually shifting the trans or letting it shift itself?
            full trim or stripped?
            • loner666
              • Oct 2006
              • 435
              Nice to see your still running the car Asylum. Nice times too.
              Best 1/4mile ET - 12.9
              Best 1/4mile MPH - 111
              1997 Ford Ranger Splash
              Daily Driver
                He's full trim IIRC, and he is also manually shifting the car at 6100 or something like that.
                He's got a nice set of DR's that are just the right size for that car, the thing hops off the line like crazy. My tires are still too large for drag racing and I think if I hack those down in size my times will drop.
                I would love a set of WOT heads too, but yeah... Money... I've also asked before and never got an answer, but I would like to know how much it is for just porting a set of heads and the valves. I do not need springs or retainers, but I can't opt those out in the store.
                • Axe_1
                  • Jun 2010
                  • 85
                  Nice looking car! That sounds like great times for the first time out with that build. The long break in period was probably the best thing you could have done also. A buddy of mine once threw his dual 4bbl 355ci together and dropped it in the car, cleaned up, then drove it home to OH from TX. He said it was the first engine he had ever built that didn't blow up from abuse. He normally beat them long before he should have.
                  Axe
                  • Rootie524
                    • Feb 2010
                    • 543
                    sweet man! are you 3500 swapped? and competition heads? nice times for sure. I'd guess you have a high 3.6X FDR based on that the 1/4 time but i've been wrong before haha.
                      He's a full 3500 and yes it has a 3.73 final drive with 3k or so stall converter.
                      • asylummotorsports
                        Banned
                        • Oct 2005
                        • 649
                        Sorry guys I haven't been on here for a while.
                        It's full trim, street legal.
                        WOT heads, Comp 536 lift, Comp springs, 3.73 FDR, LSD, 225-50-15 BFG Drag radials at 16#, and a modified FA converter.
                        Shifting manually at 6600.
                        I'm REALLY impressed with the converter in this thing! (And it gets 24 mpg!)
                        • woody90gtz
                          3400/5spd Beretta
                          • Oct 2006
                          • 83
                          Not bad for a measly Beretta...
                          91 SS . 3400/5spd - S&S, TCE, EP, FFP, SPEC, DSS, K&N . GEARHEAD dezign
