A/T to M/T
  • koda
    • Jul 2010
    • 11
    A/T to M/T
    New to the 60 degree v6 game. i recently found myself owning a 3.1L out a 90 Lumina
    i bolted a t5 to the back, now i was wondering if there is a plug n play M/T ecu from maybe the same year or later. example would a 3.4L lumina M/t ecu work
  • CNCguy
    Bisong eater :P
    • 1017
    You could use the ECM/harness from the Lumina and get a chip from a 3.1L M/T car like a Beretta/Cavalier/etc. What is it going in?
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
    • koda
      • Jul 2010
      • 11
      i am throwing it in a 86 s10, the 2.8l is no good. these chips are they available at a parts store like napa or something, or is it something i have to go to a junkyard or internet.
      • CNCguy
        Bisong eater :P
        • 1017
        Junkyard is the cheapest place to get a chip or have someone burn one for you. Does the '86 have an electric or cable driven speedo? If it is electrically driven, you may have some issues using a different ECM. Every harness will require some modifications to use for your application.
        '79 MGB - LZ9 - T5
        • koda
          • Jul 2010
          • 11
          where would you have one burned and what would i need to have one burned
