Unique Fiero 2.8 iron exh...
    Live life 3.7mi at a time
    • 4555
    We could make exhaust sound like this!
    Getting ready to experiment on a little something with a unique primary routing. Let me know what you think...
  • mickaz
    • Aug 2004
    • 350
    interesting but how???
    Mike 60degree addict.
      maybe it's just my laptop speakers and approaching deafness, but that sounded likda ricey to me....
        • 4555
        Actually, it's an exotic car sound. Since most exotic cars use a flat plane crank and same-bank headers, you hear pairing of cylinders that are both at TDC,one on the intake stroke, one on the exhaust stroke.
        Here's an example of the same situation on a v8...
        ls7
        sbf
        sbc
          so THAT'S what 180* headers mean?
          seems to work well with 8 cylinders, but on the fiero(after watching for like the 5th and 6th times), the transition from idle to heavy throttle has the "gasping" that ricers create before they start buzzing. otherwise, it does sound good.
            • 9191
            When you mentioned unique primary routing, pretty much figured you were talking about 180* headers. The sound is interesting, but not sure if its for me...
            • CNCguy
              Bisong eater :P
              • Dec 2003
              • 1017
              180° headers are very common on circle track cars. They are used to balance the exhaust pulses when the firing order doesn't go from bank to bank (common for a V. The SBC firing order is 1-8-4-3-6-5-7-2 so they group primaries 1-4-6-7 and 8-3-5-2. 60V6 exhaust pulses are naturally balanced since the firing order is 1-2-3-4-5-6.
              I vote that the Fiero must have picked up an Oriental accent while living in Taiwan. I'd say it's all in the exhaust routing and muffler. Some people here said my 3900 sounded ricey with the first muffler that was on it.
              Okay... enough fun and back to building headers.
              MinusOne - 3100 - 4T60E
              '79 MGB - LZ9 - T5
              http://www.tcemotorsports.com
                see, the 1-6 firing order of the 660s makes me wonder why this would even be necessary? exhausts left bank then exhausts right bank alternately the same way the 180* headers dump out exhaust....
                am i missing something?
                  • 4555
                  Lol. Blades come in for the new band saw tomorrow, trust me the itch is killing me.
                  Well, these headers I am talking is a 6-3-1 system, like the first video. What the intended purpose is to pair two cyls at TDC to help evacuate the opposing cylinder, thus creating the sound of three flat planes on a crank.
                  If you look into the guy's build, you will see where the primaries cross over, just don't ask me what it says...
                  Well, kinda. If you think about it, there are 3 cyls grouped together, but they are not alternating truly since one cyl in the 3-1 collector is not at the opposing position to the other 2.
                    makes sense.... if only you had the ability to cast cranks john...
                    but i guess connecting the correct sets of cylinders together would work, as long as you want to deal with the more complex exhaust plumbing.
                    it does sound similar in conecpt to Tri-Ys.... but with 2 less cylinders, and i know those headers make some hellacious midrange power.
                    • neo71665
                      its this big
                      • Oct 2005
                      • 361
                      I think I like the sound of my long tubes and flow 40
                      87 3.4 4x4 blazer
                        an X pipe on a '660 is also a huge improvement, even though the pulses are balanced it still increases the scavenging and cleans up the exhaust note.. probably better than it does on a V8. I wish i had taken some videos of my Z24 after i put the latest X pipe on it.
                        Now if we only knew someone with an engine dyno we could test shorties vs longtubes vs 180's...
                          • 4555
                          But it IS tri-y's 6 primaries, paired to 360* of crank rotation, to one 3-1 collector. Only other way to get the same scavenging effect is to do a 6-1 collector. Search 6-1 headers and tell me what you think of them
                          Still have rasp on decel/rev-down.
                          Dynoes to back theories and prototypes is a must. Tru duals sound so nice on an even-fire v6 because of the way the primaries will "twist" the pulses to create a "toilet bowl" effect in scavenging. The x-pipe will increase performance and sound because the secondaries are joined so late in the exit.
                          OOPS! I realized when I said "first video" that the 6-3-1 video was never posted because the videographer wanted secrecy.
                            LOL, with a V8, i guess there's actually 6 Y's but i see the point.
                            i see 6-1 headers for straight 6 motors.... and they look fairly straightfoward.
                            i'm interested in results here.
                            i have a hard time seeing all of this fitting nicely in a FWD application though... but i imagine it is possible with enough tweaking and prototyping.
                              so i was thinking about it a bit more....
                              combine 1-4, 2-5 and 3-6 cylinders together for this 180* effect? then to a 3-1 collector? damn these are gonna be complicated...
