turbo fiero?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    turbo fiero?
    Lately I'd been toying with the idea of EBAY turbocharging my 1985 fiero. it's a stock 2.8 that's about to receive a 4 speed manual trans. my question is, would it be worth it to turbo a stock 2.8? what size turbo should I use if I do it? I'm gonna do it on the cheap if I even do it. also, would an '85 2.8 have a roller cam? what about an '87?
    Thanks in advance-
    Eric
    the 2.8 in a fiero is a gen 1 motor: meaning no roller cams.
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      10-4, that means plan B, or C B, do nothing with the cam, C throw a flatty in the motor I'm getting,
      • 2.8-350TBI
        RWD FTW!!!
        • Sep 2009
        • 350
        GEN1 = PITA
        But it is workable.
        Instead of turbocharging, get a 3400 top end (luckily I have one for sale, pm me if youre interested), and swap that in place.
        It will save your engine the hardship of boost, will breathe more than that 2.8 will ever need to, and be more drivable, and more efficient.
        As for a cam, a "flatty" is your only option, and I would recommend it. You can talk to forcedfirebird about that, and im pretty sure hes willing to chime in on this.
        When I showed up to this forum I had the same question you did.
        Turbo my 2.8? The guys here oriented me, and now I will be doing a 3.4/3500 buildup sometime not too far.
        All that can be done for cheaper than what it would cost you to turbo that motor.
        Iron heads really flow like crap, so it is better to start off with a better suited platform, and then turbo from there if you still need more oomph.
        Hope this helps
        Originally posted by Mars
        Haha ^ Wrong Wheel Drive.
        No 60šV6 at the moment
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          well, the idea right now, is to turbo it for fun, and then when the engine kicks it, I'll swap to a 3500.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            are all 60* sixes one piece rear main seal? and is there a different flywheel/clutch between a 2.8 and a 3500?
            • Driver_10
              • Jul 2006
              • 487
              the clutch/ flywheel are interchangable between the 3500 and the fiero 2.8l. You wont have any issues there.
              • TiredGXP
                • Jun 2008
                • 107
                Don't think so. In '85 the 2.8 was an externally balanced engine. 3500 is internally balanced. You have to use the flywheel from an 87 or earlier engine.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  '85 is earlier than '87, you mean later? also, what about rear main seals? one or 2 piece on an '85? or did all 60* sixes get a oprms
                  • Driver_10
                    • Jul 2006
                    • 487
                    My bad. I naturally assumed that he had an 87 style 2.8l. Speaking of which, Id reccomend using a Fidanza aluminum fiero/ s-10 flywheel with a 93-95 3.4l camaro clutch and pressure-plate.
                    • TiredGXP
                      • Jun 2008
                      • 107
                      It was a two piece rear main seal in 85. Not sure when this changed - by 90 the Gen II engine was running a one piece seal.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        does the flywheel bolt pattern change between oprms and tprms?
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          well, It may not matter, I pulled the intake on my 2.8 to swap injectors, and it was full of crap (oily sludge that wreaked of gas), and honestly, I think I'm just done with this POS 2.8, 3500 here I come, any recommendations on what model car to get one from? I've already got a '7730 ecm, so now what else will I need to complete the swap? will a fiero spec 4 speed manual bolt up to it? any need to know info?
                          TIA-
                          Eric
                          • 2.8-350TBI
                            RWD FTW!!!
                            • Sep 2009
                            • 350
                            TIA-
                            Eric
                            Youre on the right track with a '7730.
                            BUT, if I were you, I would not use the 4 speed as it may very well grenade with the 3500's power going through it...
                            Look for a (284?) 5-speed and it should hold up reasonably well. You will need a neutral balance flywheel for it.
                            As for what car, just make sure it is an LX9 3500 and not the vvt version
                              the 3500 you'll be looking for were most commonly found in 04-05 malibus.
                              it does have the same bellhousing pattern as your fiero trans.
