WOT AFR?
  • 85maro
    • Sep 2006
    • 140
    WOT AFR?
    Where is your motor happiest? Mine seems to run best between 11.5 and 12, a little richer than other motors are typically run. It would seem they would run better leaner because of the chamber design.
    Live life 3.7mi at a time
    • 4555
    Are you talking about the hybrid motor? They do like to run a little rich. You should see the 3500's when I pull them apart, carbon city!
    • 85maro
      • Sep 2006
      • 140
      Yep. Mine already has some buildup, but that's from breaking it in. I'll have to suck some seafoam thorugh it.
        My 3500 was happiest with 26 degrees of advance and around a 12:1 AFR. Quite a few other engines that i've tuned like to be a little closer to 13:1 and 28 degrees (stock cam and SCR).
        • 85maro
          • Sep 2006
          • 140
          28* was what I ended up with.
            i always shoot for a calc'd 12.5, but from the sounds of it, maybe i should be going richer?
            • 85maro
              • Sep 2006
              • 140
              One way to find out. Ever take it to the track?
                LOL, the only vehicle capable of traveling there legally is wifey's LH0 GP.... i don't feel like pulling an 18 second timeslip
                i imagine there would a few decent places to log a thorough 1st gear or 0-60 run without attracting attention though...
                  On-ramps to the highway work very well.
                  I tuned a cammed 3500 swapped 3rd gen Sunfire the other day, we just kept doing 3rd gear pulls up to 70 ish MPH on the highway.
                  • 19Cutlass94
                    • Apr 2005
                    • 770
                    Right now with my stock 3100 PCM its got 11.4 at WOT. Probably a little too rich?
                    Ohh and Rob, PM coming...
                    3400/Getrag 284 5spd
                    350/NV3500 5spd
                    2014 Chevrolet Malibu LS
                      GM obviously didn't think so!
                      the 94-95 3100 PCMs SHOULD have a cat protect function in them, and richens up the AFR even more depending on how long you've been in PE mode...
