I relize there are a lot of variables but what would be the reasonable power exspection from a 3.4/3400 / 60-1 turbo at 15#?
Power Xspections
Tags: None
think of it this way: all things remaining the same, stuffing another atmosphere(14.7PSI) down an engine's TB will double it's HP. a 3400 is rated at what, 190HP?
assuming a good intercooler and the turbo being correctly sized, figure it would bump itself up to around 380HP at 15PSI. i don't know if a 60-1 is a good match for a 3400 though, i've never looked into them.
It's a Garrett T3/60-1 70AR 60 trim/stage III .63 exh. if you would like to check it out and give your opinion.
maybe...
there are certainly better compressors to match a 3400.
here's 3 good examples, all T04Es.
