Extreme Camaro hybrid build plus...
    Live life 3.7mi at a time
    • 4555
    I have been holding out on posting this build that's lasted a year so far, but come on inside and check it out!
    When I first started out at the machine shop, porting etc, I had a guy who got in on a group buy for a 3500 top end for his Camaro. Well, it didn't stop there needless to say.
    Started with this...
    Bought a 3500 to pirate the parts from
    Polished the valve covers...
    Then the manifold (well not complete yet, but you get the idea lol)
    But the customer wants the best of everything, so new parts showed up. Yellow springs, titanium retainers, ls1 seats, Viton seals, at this time it was SI valves (later changed them for Manley after hearing the heads were popping off the SI's)...
    Porting!
    Who need a small TB? One of our adapters and the 65mm upgrade
    • 4555
    So after some searching locally, he realized he didn't want to have anyone but us do the install, so he shipped us the car!
    So, not only did we get the car, it was chock FULL of parts he had been buying over a year or so...
      • 4555
      First thing on the aganda was to get a baseline dyno session. The motor has 13k miles on it, fresh crate from GM...
        • 4555
        Next was to start getting things assembled...
        Powdercoated the late model spindles that work for the big brake setup...
        Than a package came to my door! This is a 500hp Performabuilt 4l60 and 2800 stall..
          • 4555
          Then it was time to start getting dirty.
          Rear was pulled for Por-15/rebuild...
          Walbro time
          Rear back in with panhard relocation, LCA relocation, tubular everything...
            • 4555
            Grand national aluminum drums powdercoated and were modified to fit...
              • 4555
              Next was the ECM swap for tuning the originally OBD1.5 car...
              and it runs! Also got the Magnaflow 3" stainless exhaust in...
                • 4555
                Now that we knew the ECM would control the stock motor, time to make some changes
                Got dirty again...
                  • 4555
                  • bob442
                    Show Me Your KITS!
                    • Nov 2008
                    • 1305
                    and then...!?
                      • 4555
                      Wait! What's this? We got a shop!
                      Pressure cleaned the car...
                      Stripped the car back down...
                      Why you ask?
                      This...
                      • bob442
                        Show Me Your KITS!
                        • Nov 2008
                        • 1305
                        NOICE!!! i hope those GTA rims are staying on, thems look nice on there!
                          • 4555
                            • 4555
                            Started getting everything put back together...
                              • 4555
                              A member on an f-body forum had bent his tubulr a-arm at the shock mount, so we didn;t want that to happen. Striped the powder coating, welded in a reinforcing plate and re-coated it...
