Injector lb raitings.
  • Z26-T
    • Apr 2008
    • 486
    Anyone have a listing of what cars have what lb injectors?
    3.8 Supercharged are 36 lb
    Are trailblazer injectors 42.5lb?
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    yeah, and color codes...
    • Z26-T
      • Apr 2008
      • 486
      Yeah as in you have them or wanting a list as well?
      • bob442
        Show Me Your KITS!
        • Nov 2008
        • 1305
        Wanting a list, sorry. I've googled quite a few times trying to figure this out. I found out color codes for TBI, and Fords, but thats it.
        its pretty sweet though.
        • Z26-T
          • Apr 2008
          • 486
          From what i gather, the color codes aren't accurate... Obviously most accurate way is part #s
            Trailblazers are only 28lb/hr Not sure at what PSI though, I've heard 55 up to 63... so I'm unsure on which was used for that application.
            • Z26-T
              • Apr 2008
              • 486
              55 up to 63 psi?
                Yes I'v heard the injectors flow 28lb/hr at 55psi... and I've also heard that they flow 28lb/hr at 63 PSI... Thats what I mean by up to, as in a range of pressures I've heard that result in the same flow... hence the confusion on the actual flow.
                • AaronGTR
                  boost lover
                  • Jan 2004
                  • 708
                  No colors for most GM delphi or bosch injectors. Most are black, and a few are white. Most accurate way of determining what they are is by part number.
                  '99 and earlier 3400's used 19lb/hr bosch style injectors (possibly 3100's as well). '00+ 3400's used 22.5lb/hr delphi style injectors (rated at 55psi). Trailblazer injectors are 28lb/hr delphi style (@ 55psi). GTP injectors are 36lb/hr bosch style, but not sure what pressure they are rated at. ZZP claims they are actually 33lb/hr, but that may be at normal pressure. Lucas 42lb/hr injectors will work, as will Motron 60lb/hr injectors. I'm sure there many others that can be adopted, and RC engineering has a bunch of bosch style injectors that will drop in, in various flow rates, if you're willing to pay the price for them.
                  '97 Grand Prix GT 3800 (sold)
                  Gotta love boost!
                  • Azrael
                    Accelerating uphill in OD
                    • Apr 2005
                    • 763
                    The older Multec I's have colour bands. Red I think is 19 lbs/hr and Green is ~18lbs/hr @ 43.5 psi.
                    1995 Grand Am SE
                    • prophiseer
                      Blaspheming Heretic
                      • Jun 2006
                      • 354
                      Nice - didin't realize the 3400 piezeos were 22# . . . I might go that route instead of purchasing another set
                      The 3400 bosch-style injectors rated at 19# run 45-50psi. The older 3100s (prior to '99 or 2000, not 100% sure) use 17# bosch-style injectors at 40-48psi.
                      N-body enthusiast:
                      {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
                      {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
                      Current Project:
                      {'90 Chevrolet C1500 Sport 350TBI}
