A wee couple ecm questions...
  • 2.8-350TBI
    RWD FTW!!!
    • Sep 2009
    • 350
    A couple days ago I took a quick trip to the local JY in search of an ECM for the 3.4/3500 project, and I came back with a '7730, which seems like my best choice now that I look back on it. It came out of a beretta gt with a gen 2 3.1. I think its a 1991. Auto transmission.
    I am going to buy a 3400 swap chip from wot-tech to get it started and tune from there.
    ^^^About that, where do I find the 4 digit BCC code on the chip?
    But I am wondering...
    What sensors will I need to be hooked up to the computer?
    And, is there a list of the pin outs hanging around somehwere?
    From what I understand, this will work basically as a factory standalone unit, which is pretty cool for me because I can still run my factory gauges (and a syclone gauge cluster is coming!). Plus I can run an electric fan!
    One question about that, will the 7730 work with the VSS signals from my 5 speed?
    Any input is greatly appreciated, and thanks for helping a fellow 60º fan
    Originally posted by Mars
    Haha ^ Wrong Wheel Drive.
    No 60ºV6 at the moment
    • 9190
    See that round opening on the right side? Inside there, there will be 4 rows of numbers/letters. The top row should be the BCC.
    As far as sensors and wiring diagrams... You will need whatever sensor the ECM requires. There are most likely several 7730 wiring diagrams hanging out in threads around here. Just do a search for it, and I'm sure you will find one.
    • 2.8-350TBI
      RWD FTW!!!
      • Sep 2009
      • 350
      Okay, thanks for the halp brad
      Know aything about the vss?
      EDIT: I found this, which is a big step on my way to wiring, but how do I know which wire are which on what plug?
      Originally posted by 3XTurboAgain View Post
      1991 3.1L ECM wiring
      1 IAC
      2 IAC
      3 H/D Cooling fan relay
      4 EGR sol (A) control
      7 IAC
      8 IAC
      9 Cooling fan control
      10 Canister purge
      11 Detonation Sensor
      12 A/c comp Ctrl
      16 O2 sensor high
      19 EGR sol (B) control
      20 Fuel pump relay Mon
      22 O2 sensor low
      1 SES ind control
      3 Diag Input
      5 Data in/out
      7 TCC
      8 SPD SENS output
      10 Ign power
      2 VSS input
      3 Bypass control
      4 IAT sensor Input
      5 Sensor ground
      6 Ground
      7 5v Reg (MAP and A/C Pres Tran)
      8 VSS input
      9 Spark Timing
      10 Sensor Ground
      12 5V ref TPS
      13 EGR sol (c) control
      14
      15 TPS input
      16 Coolant temp input
      17 A/C on input
      20 2nd Gear input
      21 A/C Pres Sig
      22 MAP input
      3 INJ control
      4 Ground
      6 3rd Gear input
      7 Fuel pump relay
      9 Inj control
      10 Ground
      11 Trans PostN input
      12 Ground
      13 Dis Pulse Ref hi
      16 P/S pres input
      17 Battery power
      19 DIS PULSE Ref Lo
      22 4th gear input
      • 2.8-350TBI
        RWD FTW!!!
        • Sep 2009
        • 350
        I was going to post this in the ecm section, but I decided its better not to do so since this thread already exists.
        I came across this info at the 3rd gen forum, but those pinouts are based on the v8 computer. The pinouts on my 7730 seem to be exactly the same, but there are a few wires on my ecm that are not listed on the sheets.
        The first one I couldnt find labeling for is:
        BA9 on the 24 pin connector. It is an orange wire that splits off in two directions.
        ^^^As per 3rd gen members, that wire is BA8 on some computers, which is serial data and goes to aldl ports "e" and "m". I just need confirmation on this.
        On the black/blue 32 pin connector and is a white wire located at
        BD4 which is white
        BD15, green
        BD13, grayish blue with orange stripe (PSPS) power steering pressure switch. My truck doesnt have one, so can this be left disconnected?
        BC9 which is a light(er) green (AC REQ)
        And on the green/gray 32 pin connector:
        GF14, gray with red stripe (AC Pressure Sensor signal)
        and a red wire at GF5 (EGR sol #3 control)
        Anyone gone through this before?
