broke a rod?!
  • Jbrogan
    • Oct 2006
    • 203
    broke a rod?!
    so i have a 3100 turbocharged with a stock bottom end. i broke a rod on 9psi with a gt3076r turbo. anyone break a rod before? first time for me and the third engine ive went thru.
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    Yikes, guess you'll spend some$ on the next bottom end then eh?
    • Jbrogan
      • Oct 2006
      • 203
      yea i guess so
      1996 Beretta
      3100 SFI TURBO
      • BillS
        • Oct 2005
        • 132
        Frankly, the stocjk bottom end seems to be pretty durable and I haven't heard of many bent/broken rods or cranks on cars running reasonable boost. Youi may just be unlucky. Did you do any rod prep befoire using them - peening etc.?
        • bob442
          Show Me Your KITS!
          • Nov 2008
          • 1305
          Where did it break first off?
          • Jbrogan
            • Oct 2006
            • 203
            yea i am unlucky. i had a mechanic machine shop mount the pistons on the rods and check em thats bout it. ive never had a rod problem im wondering if i had detonation on that cylinder. i was getting on it and my air fuel dropped off to lean and it ran shitty so i let of and it ran shitty sounded like some backl firing and stalled. i looked under the car and had coolant running of the oil pan and coolant in the oil. cylinder 6 had a smashed spark plug and when i turn the motor over by hand u can hear the rod smack around.
            1996 Beretta
            3100 SFI TURBO
            • bob442
              Show Me Your KITS!
              • Nov 2008
              • 1305
              well that just sounds fucking lovely. well... up to a 3400 and run less boost and more HP, maybe lower the CR with RWD pistons
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                Detonation will kill the strongest bottom end. If you make the rods stronger the crank will break. Make that stronger and the pistons will go. Make that stronger and the cap will go and so on and so on. Better tuning will solve your problems.
                • 90BlueZ
                  • Jul 2006
                  • 83
                  Are you sure its a rod ? Piston usually break way before rod, ask me how I know
                  1993 Chevrolet Cavalier Z24
                  3400 Turbocharged Intercooled
                  MS3 v3.57+MS3X
                    Either way, carnage pics of both or ban-hammah!
                    • bob442
                      Show Me Your KITS!
                      • Nov 2008
                      • 1305
                      I agree, but that's gotta come from Betterthanyou....... Betterthanyou?
                      • geoffinbc
                        • 5831
                        Pics or Ban? Sure I have no qualms about bans. I am sure brad and ben will do the same.
                        • Jbrogan
                          • Oct 2006
                          • 203
                          ya im not sure if it detonated but im guessing thats what happened. never had the problem before and had the same tune for a long time.
                          1996 Beretta
                          3100 SFI TURBO
                          • bob442
                            Show Me Your KITS!
                            • Nov 2008
                            • 1305
                            As in 3 motors blown long time?
                            • Jbrogan
                              • Oct 2006
                              • 203
                              well first motor i melted a piston cuz im dumb and put some methanol in the gas that one lasted a year was all stock on 9 psi. the second motor i didnt even get to really run it long i got bad parts. i had my rods honed and they were not right so rod bearings went out immediately and the metal went all thru the motor and tore it up. so now im on the third motor 2500 miles in had no problems other than a exhaust gasket blowin out cuz 2 nuts fell off somehow. so its been a different problem each time. first time for this problem.
                              1996 Beretta
                              3100 SFI TURBO
