Rwd 3500/3900
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    Rwd 3500/3900
    I see several hybrid builds, why not just swap the whole motor? I think someone mentioned starter mounting, but couldn't you drill te other side of the block for a starter?
    there are already 2 3500 swapped Camaros around... the starter mounting thing is old news, with a 700R4 the FWD position works fine, with a 4L60E use a 4th gen 3.8 Camaro bellhousing, with a T5 use a dual-pocket bellhousing found on old Isuzu troopers (if i remember right)
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      mine wouldn't be going into a Camaro, it'd be going into something a little more custom, (read alot more custom)
      same thing for a twin dual cam?
        • 9190
        Mine is going into a Mustang, with a 4L60E. TDC will be the same as far as mounting up to any of the listed trannies.
        Droid via Tapatalk
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          cool deal, thanks for the info, any specific years on the Isuzu bellhousing?
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            I've never really had a chance to look at a fwd 60* bare block, is the pad there far a starter on both side, and just not machined? I know rodney dickman sells a jig to drill a rwd block for a fwd starter location, is the reverse possible?
              • 9190
              IIRC, no it not possible, as there isn't enough meat on the block anymore in that area to allow for drilling the holes. I'll see if I can find a pic...
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                Thanks!
                  bszopi is right, on the FWD block there is room for the 1 bolt but the block ends a little after that. I'm sure you could make something to support the other side of the starter but the options are pretty good with it on the stock side.
                  what trans are you looking at using?
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    maybe a G-forced T5, not really sure yet though, def a manual though,
                      • 9190
                      This might be of assistance: http://60degreev6.com/forum/showthre...t5+bellhousing
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        thanks!
                        • WrathOfSocrus
                          • Jan 2008
                          • 318
                          I believe the 94-95 S-10 2.2L T-5 has the same bolt pattern and starter pocket.
