Custom front manifold/cross-over and Downpipe.
  • AWeb80
    W-body RSTB Maker
    • Feb 2004
    • 392
    I don't think I've ever posted these pics here. the DP is about 3 years old and the manifold work was done when my engine/trans was out for a trans rebuild 2 years ago.
    I don't remember what I all did exactly off the top of my head....
    -ball joints
    -tie rods
    -Poly A-arm bushings
    -exhaust manifolds
    -various gaskets whether leaking or not
    -full trans rebuild
    -yada yada
    It's amazing how much it woke the engine up and the sound is PERFECT. I have a large port swap in the planning now, so i'm anxious to see how much that helps w/ the better flow it will have.
    Here is what it sounds like right now.
    MODS:
    -Custom front manifold - 1 5/8" primaries to 2" Log
    -2" X-over
    -Ported rear manifold
    -2.5" Down Pipe
    -2.5" In/Out cat
    -2.5" piping back to 2.5" x 18" Vibrant Resonator
    -2.25" Y
    -C6 Corvette Tips
    Here is a smattering of pics.
    And here are a few random shots. My welding skills aren't all that great, but the stuff holds, and that's all that counts right... I had fun doing it for ~$200 in materials (high-temp paint and ss flex were expensive). I plan on taking welding classes and redoing it in stainless someday when I have a better 60* in there.
    of course I had to cut the engine mount
    Had flanges cut at work. I made them ~.06" bigger than stock IIRC
    I hogged the living PISS out of the rear manifold where it meets the x-over and DP. I couldn't believe how much material was there. I used up two carbide bits w/ my dads die grinder. I know that helped the flow right there.
    The final product.
    I had to put a shield on the engine mount next to the water pump as the exhaust is right there and I was afraid it would cook that poor hose.
    Down pipe. Started with some random 2.5" piping for $50
    stock.....tiny as shit inside. I was disgusted. A hair over 1.5"....sickening.
    I cut the stock flange off and used it. Again, not the prettiest welding by a LONG shot....but it's held for a few years not and still look ok. It was a PITA getting it to fit....took ~4 hrs of cutting, test fitting, welding, test fitting, test fitting, test fitting. I about pulled my hair out.
    Not much room there.......
    here is the rest of the exhaust. I had an exhaust shop do it as they could do it way faster than I.
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    what are you welding with?
    • MY91GT(Z)
      • Sep 2006
      • 387
      looks like flux core to me i hate that stuff and have hard time with it myself
      • AWeb80
        W-body RSTB Maker
        • Feb 2004
        • 392
        a regular Miller wire welder.
        • TurboGTU
          • 453
          Sounds real good. Always liked 60* without mufflers. I did something similar . Front header rear ported cast manifold. Looks like the rear grandam manifold flows well compared to a log. Can't really feel a good difference since I still have the suck-O Cat and rear exhaust but no muffler. Don't knock on my welds. Skills and flux core own me.
            damn.... i guess this is where i post my ~80s arc welder results?
            end result was totally worth it through, right Adam?
            • AWeb80
              W-body RSTB Maker
              • Feb 2004
              • 392
              hell ya it was worth it. Just in the sound alone. I can't wait to get on a dyno....hopefully before I deploy in 2 months to see what the numbers are.
              Maybe I'll have time to throw my large port top swap on....
