Flat tappet cam and solid lifters in a 3.1?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    104* lobe separation or 104* intake center? 104* lobe separation is pretty tight for that much duration and it sounds like you will have quite a bit of overlap and some serious lope at idle.
    • trotterlg
      • Feb 2011
      • 326
      I'll the numbers they ground it to on Monday, the cam sheet says "104 LOBE CENTER" (that is bofore grinding) the cam grinder said to leave that alone, so I guess we will see what we get. It's OK if it idles a little rough, it will not be a daily driver. I'll post the real numbers on Monday.
      PS, I recall now, both lobe center and lobe seperation said 104 on the sheet that came with the cam. Does that sound possiable? Larry
      • geoffinbc
        • 5831
        Yes thats possible it just meas that there is no advance ground into the cam. Typically there is a few degrees of advance ground into a cam to improve low end response.
        When you get your cam card with the cam then post up what it says.
        • trotterlg
          • Feb 2011
          • 326
          OK, here is what it ground into, knowing not much about cam grinds you can probably give me a clue as to what it will likely do. Larry
          • geoffinbc
            • 5831
            Replied in other thread.
