Comp Roller Rockers HP gain??
  • GEARS
    • May 2010
    • 37
    Hi everyone,
    I have a HT3.4 in my 1986 S10, with a Holley 400 cfm TBI, ported intake, MSD coil, Edelbrock headers, and a large single no cat flowmaster exhaust.
    Some future engine mods I have in mind are a wet NOS kit (between 50-75), MSD Digital 6 (to deal with the NOS), Intrepid Electirc fans (just becuase...), and Comp 1.6:1 Magnum rollers.
    One question about these rockers... Comp advertises a 15-30 horsepower increase by installing them on a iron head 2.8. To me that seems a little far fetched, but then again I could be wrong?? Do you guys think I'd actually see a 20-25 HP increase using these on my HT3.4??
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    On a big V8 with stock stampings you might see that gain. But on a V6 that is 1/4 the displacement i doubt it. 10HP/10lbs of torque would be the most I would give it.
    But the other benefits are reduced valve guide wear, more accurate ratio and slightly reduced oil temps. For less than $150 they are well worth the money.
    • GEARS
      • May 2010
      • 37
      I read last night that some people with the iron heads need to shave the pushrod guides... otherwise the rods will rub and/or break the guides. Is that true??
      @betterthanyou.... I am a ferry ride away from you... Your site was very helpfull with the engine swap! Thanks for sharing your 660 knowledge!!
      • robert 1980
        • Aug 2009
        • 302
        I see there is two sets of comp rockers on the 60 degree store.Which would be better???Im doing a 3400/3500 hybrid with a high lift cam.10 extra horse sounds good for 150.
          Robert hes going from a 1.5 ratio to 1.6 so thats why he'll see a gain of possibly 10hp, our 3x00 rockers are already 1.6 Ratio. There were NEVER any roller fulcrum rockers that fit 3400/3500's made for us when there was a big deal that there would be. The only ones known to fit, which still need modification are the Comp Gold Rockers, and a few have noticed fast wear on them and havent been able to explain why. Leave well enough alone in my book.
          • geoffinbc
            • 5831
            Never had a problem on my two builds. But you always need to check.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              IIRC, a stock 305/350 tbi flows somewhere in the ballpark of 670 CFM, and probably alot cheaper than a holley unit...
              • geoffinbc
                • 5831
                That was not his question. But a stock 4.3L/5.0L/5.7L TBI is the same size as a Holley TBI for the 2.8L and they both flow around 400CFM.
                • GEARS
                  • May 2010
                  • 37
                  Well I'll just go ahead and order the rockers. If I find that the rods hit the guides, I'll just shave them down a little... no big thrill.
                  I will keep you guys posted about the install and the difference... but what I can tell you guys is that I can't wait for my NOS!!!
                    Nitrous is fun... It's got me in the 12's
