Water Outlet Differences
  • Lilchief
    • 87
    I'm in the process of putting a camaro 3.4 intake on my 3.4 powered Fiero. But I'm going to turn it 180*. I'm also changing to a 7730 DIS ECM. The original 3.4 water outlet is fairly long and angled some. Is there one that is shorter and straighter ? I was thinking if I was to use 2 water outlets and connect the hose ends together with a short piece of hose , I could mount my fiero water outlet to the second one. I would still have to do a little grind to clear everything between the intake and housing. Also the second water outlet would have to be rotated 180* so the intake mounting surface is pointing up. Hope this isn't too complicated. Has anyone done this, turning the intake 180*, ? Any ideas or advise welcome. Thanks Rick
