Weird problem after a fuel pump change
    Car is a 3rd gen Sunfire, 3500 swap with a P&P'd top end, Street/Strip cam, etc.. OBD1 piggybacked for the engine. $A1/'7730. 36lb/hr injectors.
    It had the original fuel pump from the 2.2, upon tuning I determined that it just couldn't keep up with the engine. I maxed out the VE tables trying to get WOT to around a 12.5:1, even with a dramatic BPC change it just couldn't supply enough for the engine.
    The owner purchased a 255lph pump kit from Racetronix for the 3rd gen Jbody and installed it. He brought it over last weekend for some datalogging/tuning. To our surprise it now will not rev past 6K. Once you get close to 6K it just falls on it's face like it's hitting a rev limiter (which is set to 7).
    He's called the vendor and is waiting for a response from them but i figured i'd ask here to see if anyone's seen it before.
    I can post the datalogs if anyone wants to see them...
  • MidnightriderZ24
    • Jan 2005
    • 699
    is this verified with a pressure gauge dave? maybe a line is pinched, or something overlooked?
    [SIGPIC]
    12.268@117... 11's to come!
      Haven't checked the pressure yet.
      The day we logged had some weird weather conditions and i noticed that the MAP was only getting up to around 85kpa @ WOT. I wanted to make sure that it wasn't pulling too much vacuum on the FPR so we un-hooked it. It acted a little better but i didn't get a chance to log it after. I'm hoping for Monday afternoon.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        This a E 85 car? The FPR can clog up with debris from fuel corrosion and give funky driveability issues.
          Nope, normal gas.. probably E-10 since we're in Iowa.
          • kflo 93 gt
            Bangin' Gears
            • Nov 2003
            • 238
            Modify the bucket so it gets more fuel flow. I'm guessing it's sucking the bucket dry.
            14.60 @ 96.33 for now...
            • Schmieder
              • Dec 2009
              • 766
              Not sure if you considered this but, cheap fuel pump filters don't flow as well. I got an ACDelco filter which was much more expensive (for a filter anyways) as they are designed to flow better. Suppose the draw is enough to collapse the pump filter upon itself?
              Just an idea tossed out there.
              • Daguse5853Z
                Here's yer sign
                • Nov 2003
                • 155
                I remember reading about bootleg walbro fuel pumps a few years ago.....3x00 modified might be able to chime in on that one
                95 Z26 3400/OBDII/GETRAG
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  I posted about it and informed a few members about it........ IIRC I told Jon about it (3100-modified)
                    we haven't really done a whole lot with this, i think he contacted Racetronix but not sure what they said...
