insufficient EGR flow code? manifold swap
  • oklahoma
    • May 2011
    • 20
    On Saturday I put the lower and upper intake manifolds from a 2002 3400 on my sister's 1996 3100 Grand Prix. The car is running well and the engine is more responsive; however, the Service Engine Soon light comes on after a few miles with an insufficient EGR flow code. Any possible reasons for this? The emissions on the car must be done by the end of June so I have to have the light off within the next week.
    IIRC, the EGR valve changed in 2000, are you using the 02 EGR valve on the 96 PCM?
    if not, then i would look at the ports in the intake for the EGR path, they could be packed full of carbon and causing the code as well.
      I had a newer GP with a 3100 come to me a couple years ago with the same code. The carbon was packed solid between the EGR and the TB, so I made use of a lot of brake clean and a stiff piece of brazing rod (think a single strand of wire slightly thicker than a coat hanger) and bent it how I needed to as I worked my way to the TB busting up the carbon with the rod and brake cleaner. The light still has yet to come back on some time later.
      • 95SleeperAcheiva
        ArtofOlivia"PocketRocket"
        • Jun 2006
        • 694
        An empty catalytic converter will pop that code too. Hence why a "high-flow" converter is BS. You need 3-5 PSI of back pressure from the converter to get the EGR system to work properly. An empty converter will have little to no back pressure and thus "low flow".
          Perfect reasoning to turbo everything
          • oklahoma
            • May 2011
            • 20
            That passage way from the TB to the EGR was clogged solid with carbon, sure enough. Problem solved. Thanks y'all.
            • 95SleeperAcheiva
              • Jun 2006
              • 694
              Maybe I'm a little cranky, I just got up, not enough coffee yet, so please forgive me and take the grain of salt. But, I am constantly riding my mechanics on not being thorough enough. DON'T CUT CORNERS! It'll bite you! Just like this one did. When installing this intake and with us helping you look for a problem, it was ASSUMED, that the intake was cleaned before assembly. Usually, they get cleaned before assembly and all components that get mounted to it. Thankfully this was a minor issue but, you did waste a day or two chasing your tail for something that could have been avoided had you been thorough enough.
              • oklahoma
                • May 2011
                • 20
                I get your point. If it buys me any mercy, I did pay a machine shop to clean both the upper and lower intake before I installed them!
                • 95SleeperAcheiva
                  • Jun 2006
                  • 694
                  demand your money back!
