TBs for gen II engines?
    • 9190
    Unfortunately, they aren't for sale. But, if you have a drill press, some big bits, and somewhere to get a chunk of aluminum, you can build one yourself. See attachment.
    Ford_IAC_Adapter.pdf
    • turbobuick88
      • Jun 2011
      • 25
      haha!! I have all the above! thanks man
      Later,
      John
      www.a-body.net
      Garage:
      '88 Buick Century "GS"--Gen II 2.8 MPFI, TH125HC; Being swapped to LG5 3.1
      '86 Camaro IROC-Z--305 TPI
      • 02dohc
        • Sep 2009
        • 105
        hey ive seen your car around. if you want a big throttle body i have a 65mm one from a 3.5l dohc motor. wottech has an adapter for that throttlebody on a 3100 or 3400 intake, you might need to port out the plenum. you would have to figure out the cable situation. you can come out to oronoco junk yard and pick upthe throttle body from me for $10. text me 507-696-9227
        • turbobuick88
          • Jun 2011
          • 25
          really?(well then you probably have seen how it looks now, halfway in the progress of painting it) Do you live around the Roch area? I havent seen your Fiero around do you drive something else? Oh i dont have a phone right now ether cause I spent too much on the engine and bill ect. also will it fit on the Gen II 3100 or just the Gen III? I have the Gen II intake.
          Later,
          John
          www.a-body.net
          Garage:
          • 02dohc
            • Sep 2009
            • 105
            i would think it could fit your motor. i dont know about the adapter. i just sold a turbo from one of those motors about a month ago. a motor came in the yard locked up and i took the turbo and flanges off. but i know that it fits on the small port 3100. just a little modifying and everything works. i can find out for sure if you need it. i do live between chatfield and theilman (down by wabasha). i drive a sohc neon for a daily driver. the fiero is in the middle of a motor build and swap
            • turbobuick88
              • Jun 2011
              • 25
              #21
              then it should work on mine then. I can bring the manifold with me when i come up. Do you work at the Orinoco yard?
              Later,
              John
              www.a-body.net
              Garage:
              • 02dohc
                • Sep 2009
                • 105
                #22
                yes i work there i can just match it up with an intake that i have at the yard. ill let you know tomorrow night after work. ill post pics
                • turbobuick88
                  • Jun 2011
                  • 25
                  #23
                  ok cool any 2.8-3.1 intake from 88-91 would work
                  Later,
                  John
                  www.a-body.net
                  Garage:
                  • turbobuick88
                    • Jun 2011
                    • 25
                    #24
                    any luck on if its going to match up??
                    Later,
                    John
                    www.a-body.net
                    Garage:
