3.4L Chevette / Citation X11 Timing??
  • Airbubba32
    • Feb 2010
    • 12
    Hey everyone,
    I just finished the install of a 1994 3.4L in my son's 1985 Chevette. I did not use the Fuel Injection, I went with the 2bbl carb. I used the cam from a 1981 Citation X11 - 2.8 LH7 High Output Z-code Engine, but i have no idea where to set the timming. I googled "timing 1981 2.8L Citation X-11" with no luck. Most of the repair manuals tell you to refer to the lable under the hood, well I don't have a 81 X-11 hood to refer too.
    So any ideas, I have it running and it runs pretty good but I'd still like to know where the timing should be set.
    Thanks
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    With the engine hot and at low idle, pull and plug the vacuum line to the distributor and adjust timing to 8* BTDC. If the idle changes re adjust it and re check the timing. If you can try and add a bit more but if it pings you need to back it off.
    • Airbubba32
      • Feb 2010
      • 12
      Ok I'll try that......Thanks A Lot!
