Does anyone have the length of the 3.9L LZ9 and LZG Head and Main Bolt Lengths?
Need 3.9L Head and Main Bolt Length
When I get home I'll send you the measurements I have along with the recommended kit per ARP based on my conversation with them when I looked into head studs. I would have had them on my motor but Sappy was out of town when I placed the order and by the time I got through researching and reading up on MLS head gaskets and torque to yield bolts decided they wouldn't be necessary for my power goals.Originally posted by NateD4 View PostDoes anyone have the length of the 3.9L LZ9 and LZG Head and Main Bolt Lengths?
One thing I'd like to do is address any length short comings that I have read about when installing main studs and head bolts. Mainly shunning the mains with washers.
In this case if you have good measurements I'll see if I can get the studs rolled at a reasonable price.
Here is information that I found on the forum, I believe they are from the VW application;Originally posted by NateD4 View PostI'll have to draw them and send the drawing back to check them.
Do you have any main bolt data?
Nate
Main stud info for all 60 degree V6 engines. (ARP)
8 - Studs (11mm X 1.5 & 7/16" - 20) - ATP4.65L or Undercut Short studs (11mm x 1.5 & 7/16" - 20) - ATP4.650LU
8 - Hex Nuts (7/16" - 20) - APN58 or 12 point nuts (7/16" - 20) - APN12-1
8 - Washers (7/16 ID 13/16 OD) - APW1316N
Head stud kit that works in this application:
ARP#204-4701 10pcs studs, washers, nuts
Head studs recommended by ARP based on the measurements I posted earlier.
ARP 208-5401 10 per box
