roller lifters with 2.8
  • veekuusi
    • Aug 2011
    • 205
    Excellent ideas, keep them coming.
    I have now one PMO 3 X 50 mm carburettor (made in USA) in my Ford engine.
    I am going to use it in the new Chevy 2,8 engine.
    Difficult to explain the rules but when I have less throats than cylinders , the engine size
    can be much larger than if I had lets say 6 cylinders and 6 throats.
    The Ford Engine has Eagle rods, Wiseco pistons ..... inside.
    Spent something like 10 000 dollars to that engine.
    It has 230 horsepower, 7500 rpm,
    thats the maximum you can get it N/A.
    Circle track racing, full throttle allmost all the time.
    I need more speed , more horsepower, thats why we came to Chevy 2,8 engine.
    The knowledge to that engine is allmost zero here, but in a few days I have learned
    very much thaks to internet (and this forum specially).
    And somebody mentioned Esslinger.
    Yes, one car here is having Esslinger motor.
    So this is serius racing.
      Originally posted by 2.8/3400 1985 Camaro View Post
      Ditto on the 2800 hybrid, thats the perfect motor for his application. Any reason the crank has to be from a cavvy or beretta?
      so it has the 7x crank trigger...
      but if he's going to put carbs on it then that won't matter, it will need a custom lower intake which isn't that hard to build if you have access to a good shop.
      veekuusi, the gen 3 engines have an improved oiling system that will help you out for sure in your application. The priority main feed system is great for high RPM use. They are also stronger blocks, have cross-bolted main caps and are set up for a roller cam from the factory.
      • bob442
        Show Me Your KITS!
        • Nov 2008
        • 1305
        Yep, and dont forget you can get H-beam rods made easly too, i have 2 left from my build if your interested lol.
        I would stay with fuel injection IMO
        • veekuusi
          • Aug 2011
          • 205
          Building the engine goes on.
          Block is from -95 Chevrolet Lumina 3100 and heads are from -98 3400.
          Crankshaft is a brand new 2.8 Eagle shaft.
          Allready purchased RWD timing cover.
          So far the most difficult item will be camshaft.
          I was thinking that there should be plenty of race roller camshafts from
          which to choose.
          No, there are not any.
          But with the help of WOT-TECH thinks should be OK now.
          And the second difficult part is RWD bellhousing.
          I have seen in Ebay 2 RWD 2.8 bellhousings for sale so far.
          I have bought the other (has been on trip to Finland for a month),
          other seller is not sending to Finland).
          And why I wrote this was that Crower mechanical roller lifters are coming
          here next week.
          Bought them .
          And we will see are they "drop in" lifters or what.
          • 2.8/3400 1985 Camaro
            • Nov 2009
            • 192
            Hate to be the bearer of bad news, but you got those lifters for nothing if you are using a 3100 block, 3x00s use roller lifters by default, its the gen 1 architecture that uses flat tappets. I would return them or try to sell them here or on ebay or something, they probably aren't compatible with a 3x00 block, though I may be wrong. Even if they are though, why spend $500 on lifters when you could spend much less.
            http://www.cardomain.com/ride/390342...evrolet-camaro
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              #21
              What would worry me more would be the combustion chamber being bigger than the cylinder due to the 3400's larger bore.
                • Nov 2009
                • 192
                #22
                Nope, 3100/3400 heads are fine on not only the 3.1s, but the 2.8s as well.
                However, that being said, only a 3.4 or 3400 can take 3500 heads.
                • dskopek
                  • Jul 2009
                  • 124
                  #23
                  He ordered mechanical rollers instead of hyd ones. Be interesting to see how good they work and how much midrange he gains over a hyd roller. You know it will rev with solids!!!!
                  • bob442
                    Show Me Your KITS!
                    • Nov 2008
                    • 1305
                    #24
                    A bell housing for a 2.2, 3.1-3400, and any 3800 bell housing is the same for a 4l60 or 4l65e or 5spd from a s10 or trans am/camaro, transilla might have something to bolt upto a t56
                    • veekuusi
                      • Aug 2011
                      • 205
                      #25
                      Still waiting roller lifters and roller rocker arms.
                      In the meantime been busy with transmission.
                      Chevy S-10 bellhousing came at last.
                      I made an adapter to centralize bellhousing to transmission.
                      New bolt holes have to be made.
                      I have a lathe of my own, old but working well.
                      • bob442
                        Show Me Your KITS!
                        • Nov 2008
                        • 1305
                        #26
                        Think it would have been worth it to just put in really stiff springs in the stock 3100 lifters? That's what you ended up doing right? 2.8 crank and a 3100 block?
                        • veekuusi
                          • Aug 2011
                          • 205
                          #27
                          Yes, 2.8 crank and 3100 block.
                          Custom forged pistons and connecting rods .
                          Custom roller camshaft.
                          • 01GPGT
                            Curse you Red Baron!!!
                            • Jun 2008
                            • 214
                            #28
                            this is cool
                            i like out of the box thinking when it comes to engine builds
                            92 LeBaron Convert: Does it run yet? 03 Silverado 2500HD ecsb 4x4 6.0L: dual 3" in/out race "muffler" 2005 Ford Taurus SE 3.0: DD from california
                            • veekuusi
                              • Aug 2011
                              • 205
                              #29
                              Lifting engine and gearbox to the car.
                              New engine mounts have to be made.
                              Left room in the drivers side to dry sump oil pump.
                              Not enough room for the head in drivers side.
                              Can not make headers decently.
                              Have to modify firewall , it has allready been moved 20 cm backwards (race regulation allow that,
                              and everybody does that because of weight distribution).
                              • ericjon262
                                build it.
                                • Jan 2010
                                • 2218
                                #30
                                What do you mean no room!? get out the bold BFH, it'll fit!
