roller lifters with 2.8
    wow, for all the info you post up I'm a little surprised you can't follow this one. Not once did I quote you or the photo you posted.
    The Studs Ben sells are too long for this Original poster to use look at his pictures and posts to see why I'm not going to explain that again, Mach 5 posted up a DIFFERENT part number that would not be too long for the main's alone with 1 washer, I thought it would be a good option to use over double washer's since ARP recommends not doing that. BUT After thinking it over I'm also running a crank scraper and a windage tray so the shorter stud that Mach 5 posted is too short for me.
    • NateD4
      • Mar 2011
      • 576
      #92
      Got it. It was the lack of a comment that confused me. And the fact that it sounded like the ARP would be too short.
      • veekuusi
        • Aug 2011
        • 205
        #93
        Finally got the 3400 heads back from my friend.
        He has been porting them now for half a year.
        They still need the valve job.
        New ARP rocker studs.
        Helicoil insert 7/16 " in the head .
        Valve springs seat 175 lbs and open 445 lbs.
        Valve relief in the pistons.
        TDC intake is open 5.14 mm
        exhaust is open 3.56 mm
        Thats why you need valve reliefs.
        Ford Pinto retainers, stock Chevy V6 locks and proudly made in Finland springs.
        • Mach 5
          Speed Racer
          • Feb 2007
          • 112
          #94
          pic of main studs
          Radical Revs Race Mods- RRRM
          Owner and Founder -Jarek
          • veekuusi
            • Aug 2011
            • 205
            #95
            Here are pictures of an intake manifold you have never ever seen before.
              Nice work but what are you doing with the coolant crossover from head to head?
              • veekuusi
                • Aug 2011
                • 205
                #97
                Very good question.
                I am thinking of welding a pipe to the front end of both heads.
                Thats where the coolant water comes out of the heads
                and goes to radiator.
                Allready trained some tig-welding to a spare head.
                Only problem is that the pipe is not in the highest point of a head.
                It leaves space for air bubbles.
                I think there is a similar system in 3500 heads.
                Although I have never seen a 3500 head.
                • veekuusi
                  • Aug 2011
                  • 205
                  #98
                  Some pictures of pistons.
                  Valve reliefs in final look.
                  The red thing in the backgroud is a tool to hold the piston
                  while machining it.
                  There is only 3 mm of material above the piston top ring.
                  But we think it is OK.
                  And some numbers of the camshaft that I am using.
                  It is funny , the valve lift is calculated wrong in the cam card.
                  It should be 13.2 mm , not 13.8 mm that is written in the card.
                  The push rods are angled, it changes the numbers.
                  • bob442
                    Show Me Your KITS!
                    • Nov 2008
                    • 1305
                    #99
                    Originally posted by veekuusi View Post
                    Very good question.
                    would it not be easier and cleaner, and probably seal better to tap out the frost plugs and thread some aluminum pipe? use pipe threads or get them tacked into place once they are tight..? or maybe some nice AN fittings and SS line...
                    • veekuusi
                      • Aug 2011
                      • 205
                      #100
                      Yes, AN fittings sounds and propably looks even better.
                      Comp Cams push rods.No need for special order (custom).
                      6.200" intake
                      6.400" exhaust
                      Very important that the roller tip is in the right position to valve stem.
                      Bottom end of the engine goes tomorrow to machine shop for balancing.
                      They will balance it with the clutch , but without ATI damper.
                      • bob442
                        Show Me Your KITS!
                        • Nov 2008
                        • 1305
                        #101
                        imagine pairing up the intake ports to match my headers :P
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          #102
                          you'll need to use regular pipe fittings, or an adapter instead of AN fittings going into the head, because AN fittings need a conical seat to seal to.
                          • bob442
                            Show Me Your KITS!
                            • Nov 2008
                            • 1305
                            #103
                            they would be AN on one side lol NPT on the other.
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              #104
                              they would have to be, either that or they would need a very good machinist and some huge AN fittings.
                              • veekuusi
                                • Aug 2011
                                • 205
                                #105
                                NPT 3/4 x 14 and AN -12
                                Mission impossible.
                                You can not make the thread deep enough, the tap bottoms.
                                I have to weld the fitting to the head.
                                When you are talking about cylinder heads, best welding is no welding at all.
                                But what can you do?
                                Also I made some modifications to the oil sump.
