camshaft?
  • beppe180
    • Jul 2004
    • 82
    k thanks guys! more opinions will be good too! :P
    • beppe180
      • Jul 2004
      • 82
      o yea ppl were telling me to change over too, and pistons.. now will pistons from the 3100 fit right in the 3.1L without a problem? with standard rings? and will the heads off a 3100 fit my 3.1L? is there a benefit? better airflow? opinions i need opinions lol
      • beppe180
        • Jul 2004
        • 82
        and the Old GM 2.8L stud 476530 adjustable rocker arm stud, wut yrs were they found in? any motor with a 2.8? or a specific yr?
        • robby1870
          Squaddoosh
          • 584
          I asked for rocker studs from a 1984 Chevy S-10 2.8L
          EDIT: And yes, 3100 heads will fit on a 3.1L bottom end and flow more air, especially on the exhaust side. Im sure there's a how-to on this site on doing a 3x00 top end swap, you'll need to read, cuz its not as simple ans throwing 3x00 heads on a 3.1L bottom end
          Robby Whitesell
          2006 Pontiac G6 GT
          1985 Toyota Pickup DLX
          • beppe180
            • Jul 2004
            • 82
            3100 head swap to 3.1L anyone??
            • beppe180
              • Jul 2004
              • 82
              #21
              and i m gonna go to the junker and get 3100 pistons to make higher compression in the 3.1L this will work right.. sry for all the questions.. just wanna get everything right before i start puttin this thing together
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                #22
                speaking of camshaft, how hard is it to take one out of a 3100 engine, because i want to get my regrinded.
                02 GTP - 90* > Failboat
                www.blackbombshell95.com
                • robby1870
                  Squaddoosh
                  • 584
                  #23
                  Easiest way is to pull the motor out, IMO
                  Robby Whitesell
                  2006 Pontiac G6 GT
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    #24
                    lol, can it be done without taking out the motor? how many hours would be involved?
                      • 9191
                      #25
                      When I did mine (and I pulled the motor), it took me right around 3 days. To do it without taking the motor out, you have to still have a hoist and you need to drop the subframe in order to access the cam from the wheel well. And then, you'll be working in the cramped space of the wheel well the entire time. I'd rather pull the engine and do all the major work while the engine is sitting on a stand with everything easily accessible.
                      • bluebomber
                        • May 2004
                        • 23
                        #26
                        I pulled my cam without removing the motor (not my first choice). We removed both dogbones and the lower engine mount on the passenger side. Then using a jack from below the engine, lightly jacked it up and then swung it forward slightly, it was just enough room to get the camshaft out and the new one back in. It was a 2 person job and was like our 3rd or 4th plan to get that cam out.
                        1994 Grand Prix SE 4dr - Brilliant Blue Metallic
                        Magnaflow Hi-Flow (And Bashed) Cat
                        2.5\" Split Dual Exhaust
                        Two Flowmaster 40 \"American Thunder\" Mufflers
                        7\" Cone Cold Air Intake
                        FFP Poly Motor Mounts
                        16.320 @ 83 MPH w/ 2.296 60\'
                        • v6h.o.
                          • 1418
                          #27
                          yeah the best way is just to pull the engine. you can scrape by and squeaze it through the wheel well. but thats not the best or easiest way to do it.
                          pulling the engine is the best way.
                          Colin
