3500 sensor question
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    just above the crank sensor on my 3500, there's a sensor or device of some kind, it's rather large and has 3 larger wires going to it.
    what is it? anyone know?
  • Fastmax32168
    • Dec 2010
    • 65
    I think you will find you have one on each side. I think its a knock sensor.
    Roy
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      no, this device is only on the back of the motor (right side)
      • Fastmax32168
        • Dec 2010
        • 65
        Mine had one on each side of the motor. I am still going with knock sensor. Mine went in the trash, whatever they are I didnt need them.
        Roy
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          if this is a knock sensor, it's the biggest one I've ever seen...
          • Fastmax32168
            • Dec 2010
            • 65
            Does it look like this?
            • gar70614
              • Oct 2008
              • 330
              Is it round with a 15mm bolt going through the middle of it?
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                nope, already said, not a knock sensor.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  here's a pic...
                  • Fastmax32168
                    • Dec 2010
                    • 65
                    Hmmm. My 3500 has a plug in that hole. And my right knock sensor was in the hole just above and to the left of it. It looks like a water temp sender to me. Hopefully somebody can identify it for sure.
                    • CNCguy
                      Bisong eater :P
                      • 1017
                      Never seen one in an LX9 but wouldn't be surprised if it's a block heater.
                      MinusOne - 3100 - 4T60E
                      '79 MGB - LZ9 - T5
                      http://www.tcemotorsports.com
                      • Kaiju Senso
                        • Sep 2010
                        • 82
                        There is a big plug right there in my LNJ Block
                        • boomofdoom88
                          • Oct 2010
                          • 111
                          Thats exactly what it is. The engine probably came from a van.
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            it's an Engine block heater!( car was from Minnesota!)
                            boomofdoom88, that site is very helpful! thanks for sharing!
