Pulled the valve spring off and found this. The spring shim was all chewed up and had worn a groove in the outside of the valve guide. Weird thing is the valve seal was still pretty tight on the guide, but the valve seemed a little loose to me in the guide. I don't have a dial gauge to check the run out though so I'm having the shop check it.
So basically there was no way I was putting those heads back on the engine. Luckily I still had a set of stock heads already assembled in a box back at my apartment. I cleaned them up a little and put those on with Felpro SD head gaskets and new LIM gaskets. Everything seems to be running better and no signs of burning any fluids at this point.
