Originally posted by 2.8/3400 1985 Camaro
View Post
Help with my first swap please!
I vote swap still, the TH125C is GARBAGE, it's my main reason for going 5 speed, not because my trans was toast, but because it was a crappy trans, three forward speeds, thats it. the torque converter lockup drops the rpm's more than the shifts..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Yeah, note my edit after I noticed it was a 3 spd, lol.
Originally posted by 2.8/3400 1985 Camaro View PostIf you're going for that much power you should probably rebuild the transmission, transmissions usually last 150-200k typically. After seeing its a 3 speed from what the guy above me says though, I would replace it with a performance built 4t60. And actually for $6k you could get a 3.6 DI which has your power goals right out of the box, but its uncharted territory so far as I know. And paying someone else to figure it out would put you over budget if you couldn't do it yourself. Someone seriously needs to start cranking out standalone ECUs for that motor, I want a 3.6 DI in my camaro bad...as much power as an ls1 in a small lightweight, v6, could have my handling and my power.
I would stay away from the DI motor, it would have a ridiculous pricetag just to get in the car, and we're not talking running either. spend your money wisely, get an LX9 and a cam, have a fun DD, and a reliable car."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
If you paid someone else to put it in yeah. But if you did it yourself it would cost about the same as an ls1 swap into a 3rd gen fbody does.
what bellhousing pattern dos the DI motor use?Originally posted by 2.8/3400 1985 Camaro View PostIf you paid someone else to put it in yeah. But if you did it yourself it would cost about the same as an ls1 swap into a 3rd gen fbody does."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
