  • caffeine
    • Jan 2012
    • 1489
    #316
    Ya, probably the best design intake but IMO UGLY . Would probably work well for RWD with a ram air setup.
    '86 Fiero, 3500, 4-speed
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      #317
      I'm I'm still unsure of exactly how I'm going to do my new setup, whether I'm going to take the pipe as far back as it was stock or not...
      • unchained01
        • Jan 2011
        • 388
        #318
        http://60degreev6.com/forum/showthre...or-boost/page2
        Here is a pic of the LNJ intake
        • Purple pit
          • Oct 2012
          • 718
          #319
          no it's going to be an open plenum... just not as open as it is right now! I do plan to make a fer more changes while I'm in this deep though. I'll post up pictures as they come.
          Ok I'll be watching for them.
          Grand Prix trans with 3.33FDR
            One of these days i need to find one of those plenums...
            • unchained01
              • Jan 2011
              • 388
              #321
              Can anyone shed some light on this thing? I just cam across it. Looks kind of odd. If I ever get one I would have to cut my hood and add a snorkel lol. Any benefit to these things?
              • TGP37
                Shadetree Engineer
                • Jul 2011
                • 1027
                #322
                tiny little buggers! I would have gone at least 1.5 inch, mainly because you're going to have a terrible port mismatch problem with such a small primary,
                The circumference is close enough to work a gentle taper and eliminate the reversion wall due to the turbo. The exhaust pulse will be nice and strong out of the merge, inches from the turbo.
                They'll sure spool up nice, just might start to choke around 6000-6500 rpm. True urban street turbo headers, lol. If they completely fail, it will still be a great learning experience for the next set.
                Anyways, back to your build. So much you can do in that plenum.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  #323
                  I think I'm going to do something a little different from what I have started though, I'm going to take one of my other plenums to the machine shop, and have them cut the neck out nice and clean, and then have someone with a good tig welder weld in the larger neck. I'll do more in depth stuff when I have more time to cut, grind, and have fun.
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #324
                    "stubbed" the turbo flange today... what a bitch that was... I'll get some pictures tomorrow when I wrap up the piping.
                    • NateD4
                      • Mar 2011
                      • 576
                      #325
                      Stubbed??
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        #326
                        Originally posted by NateD4 View Post
                        Stubbed??
                        formed and welded 2 short pieces of pipe into the flange, that my mid-pipes can more easily be welded to.
                        I haven't taken any pictures of the mid-pipe yet, it looks kinda crappy... it'll work, but it'll be replaced when I have more time to work on it...
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          #327
                          Pics of today's progress...
                          that's what I meant by stubbed.
                          • Mars
                            • Apr 2004
                            • 826
                            #328
                            mother of god you need to practice welding !
                            Nice work otherwise.
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              #329
                              lol! they'd look alot better if I had more time to work on them... I don't plan for this setup to be permanent, I'd like to upgrade to something stainless, but I'm short on time, and the budget doesn't allow for that right now...
                              • 23TrackroadsterV6
                                • Jul 2011
                                • 60
                                #330
                                Helpful tip on the welding, you need to leave a small gap between the tubes being joined, I usually use the thickness of the tubing as a guide, if its 1/16 wall thickness, leave a 1/16th space between the tubes. Doing this allows you to use less heat, less wire and still get good penetration of the parts being joined.
