help making 3.4 run 10s in the 1/8 cheap
  • twistedbowtie
    • Nov 2011
    • 3
    hey guys i know there are a lot on people that ask the same question. Im looking to make a 95 camaro 3.4 with 135k run 10 sec in the 1/8 while staying street friendly. i know the small things like cut weight, gears, act. but I've been looking into a lot of threads saying you can add big hp gains by swapping heads, intake/rails, ect from other 60degree motors ? can i do this with a stock short block? what would be the best heads / intake to find? are the stock heads what limits this motor or the short intake runners?
    sorry for all the questions just always wanted to turn a 3.4 up and I'm not very familiar with this motor.
    thanks, Dustyn
  • robert 1980
    • Aug 2009
    • 302
    My 3400 runs 9.7 in the 1/8
    But i have a beretta
    Jons doing a build for me right now you should check it out.
    WOT-TECH street/strip 3500 heads.Comp ported intakes and a custom camshaft
    • twistedbowtie
      • Nov 2011
      • 3
      will do man. did you bolt the 3500 heads to ur stck stortblock?
      • robert 1980
        • Aug 2009
        • 302
        Yeah but you need a 3500 LIM.You can't bolt 3500 heads to a 3400 LIM.
        But either a 3500 or 3400 upper is ok
          what 1/8 times are you getting now? and trap speed?
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Prior to this year I did many mid 9's in the 1/8th. For this year I am seeing low 9's and dipping 8's. I went from a 3.1 to a 3500, both setups were/are hair dryer equipped.
            All done in an old slow fwd Beretta using an auto.
