Exhaust flange
  • Khipset
    • Oct 2008
    • 52
    Exhaust flange
    Has anyone made a Downpipe coming from stock 3400 Manifolds? If so - what flange did you use to mate with the manifold?
    I had this cut by a friend and it used the stock 3400 gasket, or a simple 2.5 flange gasket slightly modified to fit the bolt width.
    I made this with it.
    Used only one bend for my application and it came out perfect.
    • woody90gtz
      3400/5spd Beretta
      • Oct 2006
      • 83
      That looks familiar...
      91 SS . 3400/5spd - S&S, TCE, EP, FFP, SPEC, DSS, K&N . GEARHEAD dezign
      • Khipset
        • Oct 2008
        • 52
        That looks good. I am actually in need of someone to weld it up as well. This will actually be going into an Impala (W-Body) and I know the angles are much different than the N-Body. I will post up some pics of my Manifold and see what your opinion is.
        • 19Cutlass94
          • Apr 2005
          • 770
          When I made my downpipe for my car, I just used the stock flange that was on the stock downpipe, and welded 2.5" pipeto that flange. Works perfect.
          3400/Getrag 284 5spd
          350/NV3500 5spd
          2014 Chevrolet Malibu LS
          • Khipset
            • Oct 2008
            • 52
            Slightly separate topic - does anyone know if the 3900 Exhaust manifold will bolt up to a 3400 head? Based on the Part number searches, the 3500 and 3900 Exhaust manifolds are the same, at least for the 06+ Impala. If I remember correctly, the 3500's will bolt up, so this would suggest the 3900's would.
              • 9191
              Two completely different 3500s. The ones in the 06+ Impala is the 3500VVT, which is just a smaller 3900. The 3500 manifolds that work on the 3400 is just a larger version of the 3400. So to answer your question, no, they won't work.
              Brad via Tapatalk
              • Khipset
                • Oct 2008
                • 52
                Damn... I'll stick with the ported 3400's then. TY for the info.
                • Khipset
                  • Oct 2008
                  • 52
                  Anyone know a part number for the Exhaust Manifold Studs? I seem to be having difficulty find reliable information... couldn't think of a more reliable location than here.
                    • 9191
                    Like the studs that go into the head? I got mine at Napa, PN 600-2604.
                    • alpinestar10
                      • Apr 2010
                      • 194
                      Sweet i've always sourced flanges from the yard and cleaned them up but now ill get a brand new one made with the dimensions jon awesome post
                      • Khipset
                        • Oct 2008
                        • 52
                        Thats them! Thank You sir!!
