1982 Camaro 2.8L Questions
  • OdieTurbo
    • Nov 2009
    • 17
    Okay folks! I've got some questions for the carb gurus here.
    I've got a 1982 Camaro with the 2.8L V6. I'm in the process of doing a full restomod, including swapping out my TH200C for a T-5 manual transmission.
    The questions I have are in regards to my carb and emissions controls. This car is emissions exempt due to the age. In addition, the age means that every component is about 30 years old.
    Would there be a benefit to me putting on a standard 2SE carb off of an early 80's S10 and removing all the emissions controls such as air pump, egr, charcoal canister, etc?
    One thing I see is I would not be relying on a 30 year old computer and wouldn't have to keep tinkering with 30 year old sensors and the like to keep it running. I am also aware that I would need the distributor off the same truck as well.
    1982 Chevrolet Camaro Berlinetta
    Upgrades include: 3.4L V6 (headers, 1.6 rockers, hot cam), T-5 Manual Transmission, 1986 Z-28 Anti-Sway Bars, 1987 IROC-Z Wonder Bar.
    that may work.... or you could swap in a modern V6 and have a lot more fun
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Well if he is doing a resto then he may not be interested. Yes you can add the non electrical 2SE carb to your car. You just need to use the matching distributor.
      • OdieTurbo
        • Nov 2009
        • 17
        Well, I've decided against it. I'm going to keep the E2SE and CCC in place, but I am removing the smog pump and tubing (the A.I.R. manifold leaks). As to why I'm sticking with the 1982 2.8L V6 - It's completely rebuilt; pistons, rings, cam, heads redone, new crank, all new seals, etc.
        • 2.8chevetteguy
          • Jan 2012
          • 12
          I'm a newbie and am in about the same spot. Found a cheap rebuilt 2.8 and want to go non computer distributor and a 4bbl holley.. Where do I find a non computer dist?? What years/models do I look for?? I would also be interested in your t200C 3 speed if you still have it.. I'm in watkins glen NY.. Thx will
          • OdieTurbo
            • Nov 2009
            • 17
            2.8chevetteguy - I think you can get them off any 1982-1984 S10 or S15 with the 2.8L V6. I will also not be needing the TH200c, I'm definitely going for the T-5 swap. If you'd like to buy it, it's all yours!
            And as to my above posts - I decided to use the standard 2SE carburetor and distributor w/o computer control. I ended up changing to a 3.4L V6 with headers, 1.6 rockers, and a hot cam. As much as I'd rather have the computer, it's just too much of a hassle.
            • 2.8chevetteguy
              • Jan 2012
              • 12
              T200 trans
              As long as the trans shifts well and isnt burnt im interested! my nephew just so happened to have pulled a 2.8 5 speed combo out of his 85 bird to go v8 4 speed... interested in the 5 speed trans?
              • OdieTurbo
                • Nov 2009
                • 17
                2.8chevetteguy - I have no idea if the transmission works well or not, the car has been sitting since 1995. As for the 5-speed, I already have a T-5 out of a 1995 Firebird. Anyway, I can sell you the TH200c for pretty cheap as I have no use for it.
                • 2.8chevetteguy
                  • Jan 2012
                  • 12
                  The 200c is just a 3 speed with lock up converter right. thats what i want. u said that the 2.8 was rebuilt in the car right? i doubt someone would rebuild an engine if the trans was shot so i will take the chance on it. i will need trans the torque converter and the auto flexplate from the engine. ever get to elmira area?
                  • 2.8chevetteguy
                    • Jan 2012
                    • 12
                    I have a ps box out of a monte SS to trade and i hear they are a bolt in upgrade to your Camaro
                    • OdieTurbo
                      • Nov 2009
                      • 17
                      Well, the guy before me bought it after 15 years in a barn, he rebuilt the engine without ever driving the car. So I have no idea whatsoever if the transmission works. As to the power steering box, I don't need one
                      You can have the transmission, torque converter, and flexplate. How does $100 sound? It's still in the car so it might be a little while before I have it out though.
                      • 2.8chevetteguy
                        • Jan 2012
                        • 12
                        Sounds good because it will be a while before i have an extra 100.00 . let me know. thanks!
                        • OdieTurbo
                          • Nov 2009
                          • 17
                          If you're still interested, I pulled the TH200c. My email is todd dot quigley at gmail dot com.
