Need More Power
  • ahazuarus
    tinkerer
    • Mar 2007
    • 32
    Need More Power
    Hello all,
    I recently acquired a newer car (see My Vehicles under My Profile). It has the 3400 sfi, is there a single thing I can do to obtain more power assuming it already functioning optimally?
    Thanks,
    2001 Chevy Impala (3400)
  • Merc6
    • Oct 2011
    • 23
    Welcome to the forums! That single thing all depends on how deep your pockets are and what route you take. Were you looking for something bolt on, Internal, computer tune/chip or entire engine swap?
    2013 Black Granite Metallic Chevy Cruze ECO 6MT (DD)
    2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car)
    1998 Sandrift Metallic Buick Century Limited (Traded in)
    • ahazuarus
      tinkerer
      • Mar 2007
      • 32
      I am looking for both electronic and bolt on solutions. Got a few hundred to throw at it. Engine swap is certainly out of the question. Thanks for the quick response!
      • bob442
        Show Me Your KITS!
        • Nov 2008
        • 1305
        start with a 65mm throttle body, CAI, and change the muffler, or just ditch it, it wont be that loud with the factory resinator in place lol
        • ahazuarus
          tinkerer
          • Mar 2007
          • 32
          Perfect, any electronic suggestions?
          • bob442
            Show Me Your KITS!
            • Nov 2008
            • 1305
            none really, build your own CAI and save some $ if you can get a welder, it would cost you about 90$ to build a really decent intake, if you need info i'll give you some ideas on supplys and where to get some parts. Tuning wouldnt be worth to much till more work is done to the motor if thats the plan, and i personally dont suggest putting a resistor in the air temp sensor, if anything, extend the wires for the sensor and plug it in the intake as far away from the motor as possible.
            Also, this is a personal belief, i would block off the EGR at the intake, or eliminate it all together.
            • montess408
              • May 2006
              • 391
              the first thing would be to do the u bend delete. in the exhaust. then you can get a programer for the ECU.a 3500 UIM would be a gain.
              • Merc6
                • Oct 2011
                • 23
                So where does the ECU go when you do a CAI instal?
                • bob442
                  Show Me Your KITS!
                  • Nov 2008
                  • 1305
                  simply go to a wrecker and get a ECM bracket from a 4th gen F body, or 3rd gen blazer, and bolt it to the body structure benieth the original air box. if you want to build your own, order a 3" small radious mandural bent 180* pipe out of galvinized, and for the couplers use plumbing couplings from a homedepot, and for a filter just go to a autozone or something, a filter can be routed into the fender well for an actual CAI
                  • Merc6
                    • Oct 2011
                    • 23
                    Have the VIP membership at the pull-a-part so that option will do.
                    /threadjack
                    • kflo 93 gt
                      Bangin' Gears
                      • Nov 2003
                      • 238
                      A tune would add some drivability changes that you would enjoy. Such as modifying shift points, top speed governor delete/modification, changing fan turn on temps, etc. I may be mistaken, but I think you car is tunable with HPTuners, if there is a shop in the area that works with it - that would be an affordable and worthwhile investment.
                      14.60 @ 96.33 for now...
