Building a better flowing intake
  • Big_Jeff
    • Feb 2011
    • 22
    Hey guys, so recently i've been trying to identfy the weak points of the 95 camaro 3.4l and i've came across that the intake, heads, ect are not the best flowing things ever. so i have decided i would like to try and fix this problem with building an intake designed specifically for my application. any help with identifing the design flaws with the current intake and perphaps provide some helpful tips to better increase flow would be much appreciated.
    if it helps with brainstorming lets imagine that this camaro wont have a bonnet so clearence issues shouldnt impact design to much.
    Thanks for any tips, info Jeff
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    theres a really good design out there... its off of a 3500 or 3400 SFI 00+, bolt on application.
      GM did all the work for you, look up the 3500 LX9.
      • Big_Jeff
        • Feb 2011
        • 22
        thanks for the quick response! Would it make more sense to purchess a 3500 then as a doner and just use the parts to rebuild my current 3.4l? what else would be interchangable, heads?
          Live life 3.7mi at a time
          • 4555
          Use the entire top end from the 3500 and block/rotating assy from the 3500.
          • carbon
            Procrastinator
            • 388
            Uh... use the block/rotating assy from the 3.4...
            - Ben
              • 4555
              LOL! Yeah that's what I was thinking, even if it was typed wrong...
              • bob442
                Show Me Your KITS!
                • Nov 2008
                • 1305
                someone throw up some pics for this guy of a 3400/3500 in a RWD application
                  Done... back in mockup stage. 3500/700R4 in a 89 Camaro.
                  • bob442
                    Show Me Your KITS!
                    • Nov 2008
                    • 1305
                    we are probably blowing this guys mind telling him that a top end made in 2006 will bolt ontop of his block lol!
                    • Big_Jeff
                      • Feb 2011
                      • 22
                      thanks for the pics! somewhere on this forum i read about a problem with the timing cover... anyone know anything about that. do i get gaskets for the 3500 block or for the 3.4?
                      are the new heads going to lower/raise the compression ratio? thanks for all the quick responses guys.
                      also will i have a problem using the same headers. i know they will be a restriction, if i wont beable to any clue who makes a set that will work with my camaro?
                      • NateD4
                        • Mar 2011
                        • 576
                        What about compression numbers? The older Gen3 heads on cast iron (3.4) pistons supposedly yielded high compression. The 3400 and 3900 I have both appear to have this issue as well since the chambers are small.
                        • bob442
                          Show Me Your KITS!
                          • Nov 2008
                          • 1305
                          i cant que you in on the exact CR of iron head block with 3500 heads, but the 3500 heads have a slightly larger chamber than the 3400 that usually drops the CR .46, your headers should bolt right up, and i dont recall any issues with the RWD timing cover. if you are putting a 3500 top end on your motor, you will want 3500 gaskets, how ever if you went with MLS gaskets you can change you quench a bit if its too high. I'm sick as a dog right now and my memory is lacking on the iron head info, how ever, i have nothing to do, and that i can do so i'll snoop around the site, should be easier to navigate and find what i'm after with Brads small improvment
                          EDIT:So i played with the CR calculator and got 11.5:1 CR with a .060" head gasket and 3500 heads, and that is pretty awesome!
                          Why didnt i just get iron head pistons and 3500 heads?
                          • Big_Jeff
                            • Feb 2011
                            • 22
                            ~11.5 thats not to bad! for tuning i"m going to either downgrade to obd 1 or have to go to a standalone correct? i'm making a checklist of everything... for injectors is an upgrade needed?
                            • bob442
                              Show Me Your KITS!
                              • Nov 2008
                              • 1305
                              I would swap to obdii, rather get a harness from a 96 camaro or modify one from a 00+ w body ie-monte impalla, there basically setup the same
                              As for parts that you need just strip a motor at a wrecker and take everything with you, injectors fuel rail and all
