EGR VALVE BLOCK OFF PLATE
  • beppe180
    • Jul 2004
    • 82
    k i finally got all my motor together, now ppl r telling me not to use a block off plate, they said the motor wont work as good with one. or bad for it.. wut do u guys think?
  • Maetrix66
    • 61
    Mine works fine.
    It\'s Alive!
    It\'s Alive!
    • beppe180
      • Jul 2004
      • 82
      cool. is there any benefit? or gain in performance?
        • 9189
        No gain in performance and expect to get an SES light every so often. Its not the "best" idea from an emissions standpoint, but...
        • Maetrix66
          • 61
          Benefits??
          I don't know, you might see a small benefit from not recirculating hot exhaust into your intake, but mine was installed due to the fact my passageway was SEVERELY plugged. I'm talking mystery oil and a titanium drill bit couldn't clean it out. So instead of having this ignorant looking EGR walve sticking up, I made a good looking plate to block it off. I mean, if it wasn't gonna do anything anyway, then why have it there? I am going to be running a modified tgp code, so I've just shut off the EGR code anyways.
          It\'s Alive!
          It\'s Alive!
          • Anonymous
            Mine works just fine, and thanks to Ben turning the EGR off, no SES light.
            • RednBlack
              Wood Hippie
              • Mar 2004
              • 2795
              But if your EGR works fine and no clogs, is there a point to blocking it off? I just hate to change something stock that doesn't do anything for performance. Give me 5 HP and I'd do it.
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                It will not give you any performance. Infact you may loose some milage while crusing because the ECM cannot run as lean of a mixture or advanced the timing timing as much as it could if the EGR was functioning.
                So leave it on and enjoy better gas milage and a greener earth of all of us.
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  Well said!
                  • Anonymous
                    PAVE THE RAINFOREST
                    • Guest
                      Well said!
                      Agreed.
                      And another slap for Aaron, you really are a tool, aren't you?
                      • jweir22
                        • 111
                        I thinkyou can go about 70% less hole size with no engine light coming on i just pressed a piece in that made the hole smaller only to stop the black stuff back into my intake don't have to clean it as much, but it does serve a purpose it cools the cumbustion chamber.
                        1995 Cutlass Supreme 3100 SFI
                        Cold Air K&N Filter
                        58mm TB
                        Dynomax Duel Exhaust with Performance Catalytic Converter
                        FFP Underdrive Crank Pulley
                        1/4 mile 15.65 at 90.8 mph
                        • Anonymous
                          With extremely hot exhaust gas right?
                          • jweir22
                            • 111
                            Yes the combustion chamber is way hotter then exhaust gases.
                            Cold Air K&N Filter
                            58mm TB
                            • RednBlack
                              Wood Hippie
                              • Mar 2004
                              • 2795
                              Originally posted by Aaron
                              PAVE THE RAINFOREST
                              You should have used Spel Chek. I know you really meant "Save The Rainforest."
