Newbie wanting to do 3400 (LA1) engine mods
  • brigoyanks
    • Dec 2011
    • 13
    Hi All first time to this site, owner of a 3400 sfi LA1 2004 impala with some exterior mods and light performance mods.
    looking to achieve 200hp at wheels
    anyone have suggestions as to easy mods i can do at home? i already have a wot tech competition UIM, i have 62mm tce throttle body, intake, exhaust, overkilled pcm, 180° t-stat, ZZP Downpipe, dog bone poly motor mounts, egr delete and that about it
    any more supporting mods to up the hp easily and cheaply as possible
    i was thinking maybe bigger injectors, new spark plugs, new wires, maybe a WOT TECH LIM, but other that I'm clueless as to do anything with heads cams ... but like i said I'm a dummy when it comes to all that stuff
    2004 Impala 3400SFI LA1
    Performance Mods: Custom k&n FWI, Dynomax Dual Mufflers, 180° t-stat, ZZP Downpipe, High Flow Fuel Filter, TCE Adjustable Fuel Pressure Regulator, ZZP Poly Dogbone Mounts, Overkill PCM, TCE 65mm TB, WOT-Tech Ported UIM
    SHPD, WTVFD
  • Fireball
    • Sep 2010
    • 128
    Injectors, plugs and wires won't really net you anything.
    Just keep up on the maintenance of those items, but there is no need to "upgrade them".
    Don't make enough power for bigger injectors to be required at this point.
    Headers REALLY help wake these cars up.
    Can also do a 3500 top swap (look it up, it's all over the place here).
    • brigoyanks
      • Dec 2011
      • 13
      how much hp over stock for header back exhaust?
      SHPD, WTVFD
      • Fireball
        • Sep 2010
        • 128
        I'm not entirely sure for W-body cars.
        However, for N-body cars the best results I have seen are
        + 10 peak whp for catback
        + 27 peak whp for headers
        Now this doesn't mean you'll get these numbers (may be worse, may be better).
        However this is the highest I've seen on the grand am forums as far as dyno results on relatively stock cars go.
        Note the more intake work you've done the better your results.
        After such modifications a tune will benefit you a great deal!
        • brigoyanks
          • Dec 2011
          • 13
          well then the fender wall intake, 62mm tce, ported UIM and EGR delete should help me get to that 27+ mark
          SHPD, WTVFD
          • robert 1980
            • Aug 2009
            • 302
            I have an 1989 beretta 3400 5/speed. I just did the 3500 top end street/strip wot heads
            and custom camshaft.I couldn't be happier it's not even finished with the tune.And it feels like a different car.If you plan on keeping the car just save and do it right
            • bob442
              Show Me Your KITS!
              • Nov 2008
              • 1305
              + a U bend delete and replace the muffler, and maise well do a ported lower intake and proper gaskets.
              The Ebay CAI's are garbage, build your own or modify kit that can put the filter in the front of the fender, behind the fog lamp.
              I should also mention getting polly dog bone bushings as alot of engery is lost through those.
              • brigoyanks
                • Dec 2011
                • 13
                i have a downpipe so upend delete isn't there.. i have dymonax dual exhaust catback, i have a custom intake (its fender wall tho but I'm scared to have it be behind the fog for rain and snow.. i thought about making one behind my grill) , and i have zzp poly motor mounts not the bushings, i need the bushings
                SHPD, WTVFD
                • brigoyanks
                  • Dec 2011
                  • 13
                  i might wanna do a 3500 top swap, i don't know a lot of info about it tho, plus i have a tight budget (as does every other 20 year old) and i don't really want to do a camshaft, i don't know enough about it
                  SHPD, WTVFD
                  • robert 1980
                    • Aug 2009
                    • 302
                    I didn't realize your from jersey too where about? To be truthful i dont see headers making 30 hp.
                    I've heard on a 3.8 15 to 20 but i never did dyno my car.I didn't know a lot either be you learn quick.
                    If you not to far you should check out my car sometime
                    • brigoyanks
                      • Dec 2011
                      • 13
                      30 yes including the 3500 swap and intake work
                      and i live in somerset county
                      SHPD, WTVFD
                      • Fireball
                        • Sep 2010
                        • 128
                        I think with intake work, 3500 swap and headers you'll be well above 30 hp
                        • brigoyanks
                          • Dec 2011
                          • 13
                          like closer to 40 or 50hp gain? , i have a overkill pcm too, and egr delete
                          so stock is 180
                          then add 3500 swap and I'm around 200
                          intake manifolds, tce TB, Cutsom CAI 215ish
                          headerback exhaust, pcm, tstat, egr delete, poly mounts, 230ish
                          idk this is just guestimates
                          SHPD, WTVFD
                          • robert 1980
                            • Aug 2009
                            • 302
                            Yeah thats not far from me.Well either way you won't get much from it without a good tune.But yeah if you ever wanted to check the car out let me know.
                            • kflo 93 gt
                              Bangin' Gears
                              • Nov 2003
                              • 238
                              A set of tubular headers is the next best bang for the buck. There is no debate in this situation. None.
                              Stock 3400s have dynoed a 20hp gain just by adding headers. The stock manifolds are designed for packing the engine into the engine bay, not for performance; anything but, really.
                              If you don't get deep into engines yet, don't worry about the top end swap. Put on the headers and enjoy.
                              And as far as just adding horsepower numbers together - it doesn't work like that. I used to think it did, when I was your age...
                              14.60 @ 96.33 for now...
