3.5sfi inake on 3,4?
  • Christos05
    • Dec 2011
    • 28
    Hi! some one suggest to me to put 3.5 compete intake on my 3.4..
    I search info on wich T i sould put in. and i think is the lx5 oldsmoble too.
    At the begining i lpan to put the 65MM TB. and CAI. with the intake I'll reach more HP and torque?.
    Nd its an hard jo to do? smeone can explain me how to swap the intake?. guess is not bolt-on...
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    What vehicle do you have? There are a few variations of the 3.4, of you have a 3400sfi how ever, the intake is all more less a bolt on, the throttle body you will need a TB adaptor and make a custom cable bracket, and possibly change the TB lever with your stock one. Intake requires and fpr bracket as well
    • Christos05
      • Dec 2011
      • 28
      I have a 2000 3.4 SFI.
      I need :
      - lower intake
      -upper intake
      - TB adaptor
      - Tb from oldsmobile...
      And other think look like.. what?
      I need to change the head of the motor?
      I have a Chevrolet Cavalier.
      • Christos05
        • Dec 2011
        • 28
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          only if you intend to do the 3500 upper and lower intake manifolds, if you do just the upper, I think it's damn near a bolt on and go thing.
          • Christos05
            • Dec 2011
            • 28
            the guy who wnat to sell me upper and lower intake. telle me thaht I only need de 3.5 intake gasket. and its bolt on. it's real???
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              no, the lower is not a bolt on without the heads.
              • Starglow
                • Jun 2011
                • 83
                Not quite. I think you have to use 3500 heads in order to use the 3500 LIM/UIM on a 3400 block. There are also many differences between the 3400 & 3500 UIM including MAP sensor, coil bracket, vacuum ports, and TB mount design. All can be addressed but it's not a straight bolt on and go swap by any means. There's lots of info in these forums that will answer most of your questions and I'd do some research before you start buying parts.
                • Christos05
                  • Dec 2011
                  • 28
                  If i only chande the upper. I only need gasket between the 3.4 lower and 3.5 upper. TB adaptor( for de 65mm from Oldmobile) that it's?
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    sounds right to me.
                    • Starglow
                      • Jun 2011
                      • 83
                      No...not on a stock 3400 engine. The 3500 UIM uses a different coil mounting bracket, MAP sensor, and doesn't have the same number of vacuum ports as the 3400 UIM, so you have to tap the 3500 UIM to add vacuum line connections. There are also FPR clearance issues when using the 3400 fuel rail so you may have to grind a portion of the 3500 UIM to allow FPR clearance. Sorry guys, but putting a 3500 UIM on a 3400 is not plug-N-play despite what those who haven't actually done it themselves may think or tell you. Yes, the 3500 UIM does bolt on to the 3400 LIM, but that's where the similarities to the stock 3400 UIM end.
                      • Christos05
                        • Dec 2011
                        • 28
                        with this is plug n play? http://wot-tech.com/shop/gm-60v6/com.../prod_174.html
                        • Starglow
                          • Jun 2011
                          • 83
                          It's a good start and takes care of some of the necessary changes, but you'd still have to modify or adapt the 3400 coil mounting bracket in addition to the MAP sensor. The 3500 MAP sensor requires an adapter cable to connect it to the 3400 engine harness MAP connector. Using the 3400 MAP would require a vacuum port the 3500 UIM doesn't have in addition to the MAP mount being different.
                          • Starglow
                            • Jun 2011
                            • 83
                            Mike @ Milzy Motorsports has an adapter kit for the 3400 coil bracket as well as the MAP sensor harness adapter. I'm not sure that spending a few hundred dollars just for a 3500 UIM swap alone would be worth any small performance gains versus doing a 3500 top swap or complete 3500 engine swap though.
                            • Christos05
                              • Dec 2011
                              • 28
                              I think only do the top swap.. too much cash for noting. i think i'll only change de TB. I'll take the TB adaptor and if one day i want to do the total swap its the same Adaptor...
