I want to compute the compression ratio for my particular build but after doing a search have come up with conflicting values.For a 3400 I need:Head gasket bore dia. and compressed thickness,combustion chamber cc,piston dish cc and piston to deck clearance.Thanks for your help.
Compression ratio
Tags: None
Have you tried using our CR Calc? All the default values for the engines should be correct in there.
Brad via Tapatalk-Brad-
i know a lot of the newest stuff isn't correct (gen4 and HFV6) and some LQ1 stuff is missing as well.Originally posted by bszopi View PostHave you tried using our CR Calc? All the default values for the engines should be correct in there.
Brad via Tapatalk
OK,got the specs that I needed.The combustion chamber for a 3400 is 28.6 as is the piston dome volume is this right,just a coincident they're the same ?
