Thoughts on Crank case evac systems?
  • gectek
    Banned
    • Aug 2006
    • 1472
    #31
    Least amount of effort and easy to find parts at the yard. They will work either 3 types of AIR/vac pump also. 3 wire or 2 wire.
    • TGP37
      Shadetree Engineer
      • Jul 2011
      • 1027
      #32
      Venturi Effect? Maybe aim a vac line (steel) into the ITB's and have them merge into a collector that routes to the crankcase. When you go wot, the rushing air will make a vacuum in the collector and crank case, drawing blowby back into the intake to be used.
      My noob idea, lol
Name:	ITB Venturi.jpg
        So many are trying to avoid recirculating that crankcase vapor into the engine though...
        • TGP37
          Shadetree Engineer
          • Jul 2011
          • 1027
          #34
          I should've read the entire thread, the slashcut method is interesting (new to me) but I can completely understand the process. I might try something like this.........I learned something new today
