Compression Ratio Question
  • Hard Driver
    • Aug 2010
    • 77
    I found some after market 3400 dished pistons that didn't have the dish cc listed but did give 3.140 in. dia. .270 in. depth which I calculated as 34 cc.These are suppose to be a replacement for stock pistons which I see listed as 28.6 cc. Anyone want to do the math and see if I got it right?
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    • Hard Driver
      • Aug 2010
      • 77
      That's where I got the specs for a 3.4 and 3400 engines,but doesn't help in determing the cc for an aftermarket replacement piston,which you would think would be the same as stock.
      • mfuller
        Mr. Common Sense
        • Nov 2003
        • 374
        RockAuto lists Sealed Power replacement pistons with the dish as .275 deep x 3.180 dia.; so I'd say you're right in the ballpark.
        Matt
        • Hard Driver
          • Aug 2010
          • 77
          The compression comes out 9:1 depending on overbore / head gasket,etc. using 3400 heads on the 3.4 block,which is what I'm looking for.
