3400 LNJ upgrades
  • Kaiju Senso
    • Sep 2010
    • 82
    3400 LNJ upgrades
    Ok I had to drop the engine out of my Fiero to fix a transmission leak and since I recently graduated with a BSME, why not treat myself to some performance mods.
    So I contacted Ben at WOT tech and within my limits (keep motor disassembly to a minimum because of low miles), he suggested the Strip cam with the Comp 26926 valve springs and the custom length pushrods. Then to upgrade my fueling from the 3100 injectors, I got the 28# injectors from a Trailblazer.
    Still need to find the connectors for the injectors and I'll probably be switching over to an upper intake from an Alero (the one on there from a van was purely a cosmetic decision) and maybe delete the Fiero air filter canister for a cone filter. Getting the PCM tuned in person (Sinister Performance) for the modifications.
    So far the car has been running with a 98 Monte PCM, fuel rail and injectors, Van cable driven throttle, external crank trigger and added the 24x sensor, and coil pack setup from an LA1. "Trueleo" headers with 2.5" collectors, no cat to a West Coast Fiero "cat back" with the Spintek muffler. EGR delete, rear O2 delete, EVAP not programmed correctly, and AC pump attached but the lines not hooked up yet.
    Any completely generic ideas on the power I might gain? Of course I plan on getting a dyno result once I feel the car is ready, but until then I'm curious. People always ask how much power I'll gain and I have no clue.
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    You might gain 20-25 whp from the cam, injectors, upper intake swap, & tune.
    The power should be more aggressive and hold out longer, so the number increase in power is not a completed measurement of efficiency. You have to factor in the ability to sustain the added power and how soon it comes alive out of the gate.
    A vehicle that has 400 hp could potentially be slower than a car with 300 hp if certain factors are incorporated.. Such as, availability of power/torque.
    If the higher horse engine is slowly or making low power (200hp) until its short burst at 6500 to 7000 rpm's where it hits it target 400hp versus the 300 hp car making 90% power starting at 3000rpm's and peaking from 5500+ its 300hp. That 300hp car would be as fast or faster than the 400hp car.
    I was bored.
    • Kaiju Senso
      • Sep 2010
      • 82
      I was bored.
      Ya I get that and all but that's harder to explain to someone who isn't car savvy. Thanks for the input, I'm looking forward to seeing how the car feels with the cam.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        any updates for us?
        • Kaiju Senso
          • Sep 2010
          • 82
          any updates for us?
          Of course! Just a little behind because of my Baja competition.
          Only got the cam in during this round of pictures. Been working on the valve springs this last weekend and need to upload those pictures. Got the gasket kit and my reprogrammed PCM back, just waiting on my replacement transmission...
          • Kaiju Senso
            • Sep 2010
            • 82
            A few valve spring pictures. I used the compressed air in the cylinder trick so I didn't have to pull the heads.
              That ring gear doesn't look too happy. >.<
              I've read coiling some rope in the cylinder through the spark plug hole and running the piston up the cylinder till the rope is tight against the head works well too.
              On a side note, where did you get that drip pan for your engine stand and what did you pay for it?
              Sent from my Sony Tablet S using Tapatalk 2
              • Kaiju Senso
                • Sep 2010
                • 82
                No idea on the pan, we've had it forever at the shop I work(ed) at.
                More pictures from today, starting my new job this week so probably will have to wait until Saturday to finish the motor and mount the trans to it.
                Does anyone know about a pilot bearing to install on the crank when switching an automatic to a manual? My boss mentioned it might be why the trans broke.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  I don't think the fiero four speed uses a pilot bearing, I don't think the input shaft is long enough.
                  • Kaiju Senso
                    • Sep 2010
                    • 82
                    After some research it seems none of the FWD manual trans used pilot bearings. Definitely none in the Fiero.
                    Question on my 28# trailblazer injectors. Does anyone know what connectors are compatible with them from other platforms? I believe this injectors are from a 4.2L Trailblazer, guessing 02-04? Those are hard to come by at Pull-A-Part so I'm hoping something else uses the same connectors.
                      My 4t60-e to 284 swap did not require a pilot bearing.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        [QUOTE=Kaiju Senso;454499] My boss mentioned it might be why the trans broke.
                        QUOTE]
                        Looks like FOD to me.
