3100 Injector mod
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    3100 Injector mod
    I'm looking for bigger injectors for my engine. one day i will put a turbo on it. i was wondering of a part number i would need to put bigger injectors on my car. would i require a pcm that supports it?? i probably would put the bigger injectors on first and later turbo it.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • 9191
    Bigger injectors are worthless without a PCM programmed for them.
    • funky3821
      • Mar 2004
      • 36
      I hear that DHP will be able to help out on the Power control module.
      I think they were 26# injectors instead of the 19#/22# that come stock on the 3X00.
      • blackbombshell95
        Kaiō-ken X 10
        • Jun 2004
        • 1386
        what exactly is dhp, i've seen that word on the boards but don't know what it means. 26# injectors? what car is that off of, or is it aftermarket.
        • ikessky
          • 614
          DHP = Digital Horse Power
          They can upgrade your PCM, but as far as I know, they do not make larger injectors.
          • germ
            • Mar 2004
            • 76
            dhp will not touch your obd 1.5 pcm at this time
            and if you are able to get a turbo going, get the 42.5# Lucus 009's from www.zzperformance.com and make sure to get your pcm tuned somehow otherwise just run very low boost, like 5 psi on stock injectors
            • ikessky
              • 614
              Hmmm...... Didn't Brad get a reprogram from someone a while back?
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                is it that hard to get a pcm done for a 3100? how will my pcm work with the 3400 top end swap.. also with the P&P job?
                • ikessky
                  • 614
                  Your stock PCM will work fine with a P&P and the top end swap.
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    how much horsepower might a tuned pcm give me with a ffp pulley, hai, catback, P&P heads intake throttle/3400 swap compared to a non tuned pcm. a few horsepower?
