3100 v6 not runnin good
  • tkjackson02
    • Mar 2012
    • 16
    Alright I've replaced everything I can think of on this 95 Z26..... When its cool outside car runs great, but when it's warm out it runs like crap!? Sputters at all speeds and occasionally dies when coming to a stop. On another note even when running like crap if you put your foot down its a rocket? Any help I'm goin nuts!!!!
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    What have u replaced? Any codes?
    • tkjackson02
      • Mar 2012
      • 16
      No codes, Have replaced Intake Gaskets, Plenium gaskets, valve cover gaskets, timing cover gasket, Main seal, plugs, wires, thermostat, TPS, IAC, Map, Coil packs, Any Ideas?
      • TGP37
        Shadetree Engineer
        • Jul 2011
        • 1027
        Are you saying it runs good when the engine is cool, bad warm? Or ambient temp?
        If the car runs bad when warmed up it could be a leak in the exhaust upstream the o2 sensor, the o2 sensor itself is dead or one of the wires is shorting/cut.
        Air, Spark, Fuel & Compression.....the 4 main things to check.
        Since it runs strong at wot, I would check for exhaust/intake leaks. Minor leaks cause the most disturbance at idle and less under load.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Do a vacuum leak test. Probably have a cracked plenum. Could be MAF sensor too.
            95 3100, not an A-body = no MAF.
            • bob442
              Show Me Your KITS!
              • Nov 2008
              • 1305
              Soap and water spray all over the ignition, check wires, coils. Tps could be faulty, check fuel pressure, pump could be failing when it gets warm.
