2.2l bell on lx9. whats the best flywheel for it?
  • caffeine
    • Jan 2012
    • 1489
    Originally posted by grnrdragon View Post
    so what Ive measured center of pp bolts straight across is 10.5"
    I just put a FWD flywheel on top of a RWD flywheel and I can tell you that the pressure plate bolt pattern is the same.
    '86 Fiero, 3500, 4-speed
    • grnrdragon
      • Apr 2010
      • 46
      I wonder if anyone knows if the v8 stuff is close enough to work? I think it would be nice to have more options.
      • caffeine
        • Jan 2012
        • 1489
        My LT1 flywheel has a similar crank flange pattern but the bolt circle is larger. Hard to say without pulling it off the motor if it could be redrilled.
        Probably wouldn't fit within a 60* bellhousing though since the diameter iirc is 13" or 14". You could use a v8 bellhousing with the speedway motors adapter.
