Need Compression, lots of it
  • yeyo_racing
    • Mar 2005
    • 78
    Ok, guys. It's been a while since I last posted. My Turbo Fiero has a stock 2.8 iron headed with TRW flat top forged slugs freshly rebuilt with a custom cam for the turbo setup, so it shouldn't be tired but it's running with low compression. Part of it is my fault. I gave it hell while I was tunning it and once or twice ran a tank of regular gas and it was knocking with it.
    I ran a compression test and all cylinders show mid to high 90 psi, with a little oil compression goes up....sooo, the rings are shot. I'm going to re-hone it and install new moly rings, but I want compression...lot's of it. At least 160 psi, the more the merrier.
    I read a thread about using flat top 2.8 slugs with a 3.1 crank by shaving the top of the pistons. See thread here ->http://60degreev6.com/forum/showthre...Engine-rebuild
    I have two spare TRW forged slugs to check how much beef they have. Has anyone done it and ran the engine? How was it?
    Guys, note I want to get good compression with the least amount of money invested, so don't suggest new forged slugs. I already have the DIS block, DIS 3.1 crank, rings and gaskets it's just matter of getting into it. Once I get it running I'm going to swap to DIS.
    What do you think?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    I never ended up milling the pistons. I milled the deck and heads a bit but the intake did not need to be touched. I got it just over 9:1 compression. I only used calculations though I did not CC the heads or pistons I was seriously short on time. I was driving on an engine that was burning a quart of coolant on every trip to work.
    But if your doing a turbo build why are you looking for sky high compression?
    • yeyo_racing
      • Mar 2005
      • 78
      No real reason, just want good compression with what I have. Building it just for shits and giggles I guess. I'm going to keep it low on boost, around 6psi. If it blows up then I can begin a new engine project. I guess I'm just looking for an excuse.
      • TGP37
        Shadetree Engineer
        • Jul 2011
        • 1027
        Applied vacuum to the crank case can increase ring seal, reduce blow by and extend oil life.
        • yeyo_racing
          • Mar 2005
          • 78
          Huh, you want me to run with a mighty vac hooked up and pumping? Please explain.
          Although running turbo, it always had vacuum to the crank case. At least one valve cover hooked to air filter box and the PCV completely vented to avoid pressurizing it.
            Some race cars run vacuum pumps.
            The vacuum on the bottom of the rings helps expand them and suck them against the bottom ring land (where the combustion pressure is trying to push them off of, releasing pressure), sealing them against the walls of the cylinder.
            Originally posted by http://nutterracingengines.com/racing_oil_pumps/crankcase_vacuum_facts.html
            FACTS ABOUT CRANKCASE VACUUM
            The Cheapest Power You Can Buy
            What is the advantage to using a large amount of crankcase vacuum in a race engine?
            HORSEPOWER; WHAT ELSE?
            And it is the cheapest HP you can buy. If you can achieve a crankcase vacuum level of at least 8 inches HG, you will very likely realize an immediate power gain of at least 15 HP.
            If you run a dry sump system with a three stage pump (one pressure stage, two scavenge stages), in most cases you cannot achieve a sufficient level (8 "HG) of crankcase vacuum to achieve that power gain. The extra cost of a four stage pump will net you around 15 HP in most cases. At NRC, it costs less than $100 for that extra stage. How can you beat that price for an extra 15 HP?
            HOW IT WORKS
            The reduced pressure ("vacuum") in the crankcase is generated by having a substantial excess of scavenging capacity with respect to the engine's oil flow rate. The "vacuum" increases the pressure differential across the ring package, producing an improved ring seal. The improved ring seal allows the use of a low-tension (reduced friction) ring package, yielding a power increase as well. Further, the reduced crankcase pressure dramatically reduces windage losses at high RPM.
            Here are a few observations we have made over the years of developing winning race engines. First of all, in most engines, the expected power gains will occur with 8 to 10 inches HG crankcase vacuum. Beyond that point, more vacuum does not generally produce any measurable power gain until (a) you get more than 20 inches HG of vacuum AND (b) you are operating in excess of approximately 8300 RPM.
            However, we generally size the systems on our engines to produce around 14 "HG when the engine is fresh. That provides sufficient capacity so that as the engine wears and blowby increases, there will still be sufficient scavenging capacity to achieve the 8"HG minimum, and power does not drop off noticeably.
            If you want to run a high level of crankcase vacuum (18 inches HG or more), there must be provisions in the engine to supplement the lubrication that used to occur when oil was being thrashed about by the moving parts ("windage"). There will likely be problems with at least wristpin and cam follower lubrication. The best solution will be the addition of piston oilers and, if your engine has a flat tappet cam, provisions for extra lubrication of the cam lobe-to-lifter interface will certainly be required. If you are trying to achieve over 18 "HG, you will need to install special crankshaft seals (front and rear) which have the sealing lips reversed to hold that higher level.
            In order to achieve 8 "HG or more, the engine must be well sealed. In order to check for leaks, you should pressurize the assembled engine. You will need an adjustable pressure regulator with a low range (like 0 - 10 psi) air pressure gauge. With the engine completely assembled, cap off the fitting that feeds the oil into the main oil gallery, and cap off the scavenge exit fittings from the pan. Install a pressurizing fitting into one of those caps.
            We use 6 to 8 PSI (which is equal to 12 - 16 inches HG) of air pressure to test our 8 - 14" engines. Start with the regulator set to ZERO and slowly add pressure, up to the max test pressure you decide to use, and listen for air leaks. If you hear any and can't pinpoint the source, spray some windshield foamy cleaner in the area with a hand spray-bottle. NOTE: You will get better sealing with the cork rocker cover gasket than with the rubber steel lined rocker gaskets.
            You should be aware of a few potential glitches. Some silicone sealers cure differently than others, and most take weeks to cure if it is 1/8” or thicker. An uncured bead of silicone sealant will tend to be pushed out when pressure is applied or sucked in if not cured long enough. At NRC we think the best silicone sealer is the OEM stuff, and the Permatex Ultra-Gray is also a good product. The OEM and Permatex Ultra-Gray tend to cure harder on the exposed areas which makes it a little harder to be pushed out or sucked in. However, both these products take a considerable amount of time to fully cure when the bead is thick.
            We have found that the softer curing stuff tends to develop leaks after the engine has been placed in service, because it moves around during the race. Recently, we have been experimenting with a two-part silicone, which is similar to two-part epoxy, but looks and feels like silicone and cures for limited use in about 30 minutes, and completely cures in 24 hours. So far, the results are encouraging.
            DRY SUMP OIL PANS
            The pickups in most of the aftermarket pans are horrible. The pickup fittings which are usually found are rectangular boxes with sharp, square corners. Those square corners play havoc with the orderly pickup of scavenge oil and add to the turbulence and aeration which occurs at that end of the system. A good hint about how the pickups should be formed can be seen by examining the interior shape of the pickup attachments on your wife's vacuum cleaner.
            Next, almost all the aftermarket pans use dash-12 scavenge fittings. Common sense says there is more volume inside a given length of a dash-12 hose than in the same length of a dash-10 hose. Using the smaller dash-10 hose causes no meaningful increase in flow losses, but it causes a larger percentage of the hose volume to be filled with oil instead of air. Reducing down to dash-10 scavenge lines will help achieve a higher level of vacuum. You can buy the reducers from the common suppliers such as Moroso.
            As far as pan design is concerned, the wider and deeper the pan is, the easier it is to control the thrashing of oil, and the easier it is to scavenge the pan well. We also found that the better the pan design (wider, deeper, with scrapers, louvers, one-way-mesh, etc) the expected gains from a high vacuum will be less. The high-vacuum system will produce the best power increases on engines with shallow pans, which are often required as a result of engine placement restrictions or from chassis construction.
            • caffeine
              • Jan 2012
              • 1489
              It sounds like you we're running without any vacuum to the crank case. Something like an exhaust slash cut might be the way to go for a turboed engine.
              '86 Fiero, 3500, 4-speed
              • TGP37
                Shadetree Engineer
                • Jul 2011
                • 1027
                My turbo would smoke far too much with out some form of vacuum induced ventilation. The way you have it, you will get more blow by, reduced oil life and faster ring wear.
                I routed a line to the exhaust past the O2 sensors from the PCV port. It draws the crankcase vapors and induces a nice vacuum which is proportional to exhaust flow.
                Or you can get a vacuum pump designed for this kind of thing.
                  When i finally post the videos of my car going down the strip you'll see why i'll never use slash cuts again.. smokey
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    Catch can?
                      not sure if that would help or not, i still need to hook up a MAP sensor to a valve cover and see if they are even doing their job.
                      • Guest
                        Don't shave the tops of the pistons especially in a turbo setup. You need that top of the piston to be a bit thicker than even factory with a turbo as increased heat from combustion will wear out that top ring or possibly burn it if the ring land is too thin. not only that, but the piston will be weaker too. Not good with boost.
                        I say a rehone and new rings and give it a shot. only way to really get more compression is to up the compression ratio.
                        • yeyo_racing
                          • Mar 2005
                          • 78
                          I was afraid you were going to say that. The little angel on my right shoulder was telling me so, but the little devil is constantly saying "to hell with it, blow it". lol
                          So now that everyone is talking about blowby and damaging rings, how can I avoid it? What would be the best crankcase ventilation setup?
                          • yeyo_racing
                            • Mar 2005
                            • 78
                            My PCV is setup like this.
                            I initally had the PCV hooked up to the UIM, as stock. The stock breather side was never pressurized, it was always hooked up to pre-turbo / filter box, thus having vacuum at both sides. Then switched it to the setup of the second pic, basically removing the PCV valve and installing a breather. Why shouldn't that work?
                            • caffeine
                              • Jan 2012
                              • 1489
                              The breather should be on the filtered air side and vacuum needs to be applied to the valve side. There is no vacuum applied by hooking it up to the air box.
                              The way it is setup stock is so air comes in to the crankcase from the air cleaner, then is drawn from vacuum into the intake manifold where it is burned. The vacuum from the intake is what draws it through the crankcase, the filtered air side is just to make sure the air is filtered, and also if a MAF is being used to make sure that the air being breathed is metered.
                              When an exhaust slashcut is used it draws the air through the crankcase and into the exhaust, instead of into the intake. There is still vacuum being applied in this case.
