Crankshaft weights?
  • ItsVince725
    Crusing Buick Style
    • Oct 2012
    • 86
    Crankshaft weights?
    I heard something from a friend about cars having extra weights added to the crankshaft to make the engine smoother, and that these weights apparently rob the engine of power.
    Is this a thing, and if it is, does my 3100 SFI have them?
    Every engine has counter weights on the crank. If they didn't, your engine would shake itself to pieces. If you want your engine to run smoother (and it already has a clean bill of health) have the rotating assembly balanced if you have plans on a rebuild. Not only will this make your engine run smoother, but it will free up a little horse power and allow your bottom end rev higher safely.
    • caffeine
      • Jan 2012
      • 1489
      I've heard of knife-edging the counterweights as well but I have no idea what kind of a difference it makes.
      '86 Fiero, 3500, 4-speed
        Knife edging is to help the counter weights slice through the air/oil mist to reduce drag and pick up a little power by reducing parasitic drag.
        • ItsVince725
          Crusing Buick Style
          • Oct 2012
          • 86
          I see my friend was full of crap. XD
          Well, thanks anyway.
          • caffeine
            • Jan 2012
            • 1489
            Maybe he was talking about balance shafts?
              Not totally.
              Sometimes when a crank is balanced weight has to be added in spots to balance out.
              • ItsVince725
                Crusing Buick Style
                • Oct 2012
                • 86
                Could be...but I didn't think you could even remove those.
                • caffeine
                  • Jan 2012
                  • 1489
                  I think you can on certain engines. I've heard of removing them on later quad 4s and other 4 cylinders.
                  • ItsVince725
                    Crusing Buick Style
                    • Oct 2012
                    • 86
                    My friend did once have a DOHC Dodge Neon R/T, so perhaps with the Chrysler DOHC four you can actually do that.
                    But probably not with a 60 degree V6.
                    • caffeine
                      • Jan 2012
                      • 1489
                      60 degree V6s don't have balance shafts
                      • ItsVince725
                        Crusing Buick Style
                        • Oct 2012
                        • 86
                        Wow, I didn't know that.
                          60V6: naturally smooth.
                          90V6: naturally unbalanced.
                          the LQ1 has an intermediate shaft, but i wouldn't call it a balance shaft. seems to be more for driving the oil pump than anything.
                          the newer DOHC (high feature) 60V6 MAY or may not have them, i haven't looked at them in a while.
                          also, removing weight from the crank(without considering inner-engine aerodynamics) will essentially be the same as lightening the flywheel/flexplate. it's just taking weight out of the rotating assembly.
                            And drive the timing belt.
                              ehh... i forgot that the LQ1 has the crank drive the timing chain, which drives the int shaft which drives the cams...
                              i'll learn of the LQw1n soon enough.
