Valve Catastrophe?
  • Kaiju Senso
    • Sep 2010
    • 82
    Valve Catastrophe?
    So it looks like my timing chain must have broken. Car was idling fine for maybe 20 min then cut out at the end of the driveway and wouldn't restart. Didn't hear any serious "stuff breaking" noises when it happened, it just died. Cranking sounded funny, tried to see into the oil fill hole, decided finally to just pop off a valve cover.
    Comp 26986 Valve Springs
    WOT Tech Strip Cam
    matching custom length pushrods
    everything else stock 2005 LNJ 3400 (Chevy Equinox, transplanted into Pontiac Fiero) maybe 2000 miles on the engine when in the Equinox, another 1000 in the Fiero with stock valvetrain, and less then another 1000 miles with this valve train before something broke.
    Worth it to try and open the timing cover and fix what's broken while in the car or is it definitely (probably) screwed so needs to be pulled for a rebuild?
    chain or the cam dowel pin.. i'd pull the cover while it's in the car to take a quick look.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      I'd guess the pin. If the chain snapped it'd most likely have bound up around the crank sprocket and started to make some noises.
      • Kaiju Senso
        • Sep 2010
        • 82
        I'm just worried some of the valves might be toast.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          a comp test would help you figure that out once you find out and fix the rotational issue.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            good thing you have a DRTC on the way. or at least, as long as the Fiero isn't your daily driver...
            • Kaiju Senso
              • Sep 2010
              • 82
              No Fiero isn't a Daily, especially in Winter. And actually this problem occurred a while ago and helped persuade me to get in on the Double Roller Timing Chain group buy.
              The cam bolt loosening seems more plausible to me then the chain breaking. I thought the timing might have been a tooth off when I first started it so pulled the cover and realigned the marks, but had a bit of trouble getting a good angle to torque the bolt down while keeping the gear from spinning. If the dowel pin is sheared off, it'd probably be near impossible to put a new one in with the engine in the car, there is barely enough room to get the timing cover off.
              I'll probably just drop the cradle again, and I'm still expecting some broken valves. I've seen some nice pictures... Might be time for another upgrade, cylinder head porting with 3500 valves sounds like a plan...
              • TGP37
                Shadetree Engineer
                • Jul 2011
                • 1027
                +1 though funny sounding crank, might be the chain.
                The engine will run with chain off by one tooth. It is either 12 or 7 degrees difference adv or ret. It won't run it's best, but it would run.
                I wonder if the oil pump shaft snapped, no oil pressure is no fuel pump? (in case of accident)?
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  Could be a snapped cam shaft. If the oil pump section snapped, it'd still start.
                  • TGP37
                    Shadetree Engineer
                    • Jul 2011
                    • 1027
                    Yeah, the stock ones snap but they have WOT cam which I believe are solid. I doubt it would snap unless something seriously went wrong somewhere else.
                    • Kaiju Senso
                      • Sep 2010
                      • 82
                      Engine cradle came out this weekend, should have pictures of what happened to the engine by next weekend. I'll remember to use locktite on the assembly, but which color?
                      • Mars
                        • Apr 2004
                        • 826
                        Yeah it's a solid cam, so I bet it isn't broken.
                        I've wiped a locating dowel off on my 3500, i suspect that happened. It sucked. Motor was in bad shape after that, bent all the valves, ect. I'm pretty sure you toasted some parts in there.
                        I always LOCTITE red that bolt now. and torque to spec.
