2.8 swaped 3400 passed emissons in wisconsin
  • Berettaspeed
    • Apr 2004
    • 109
    i don't know of anyone who has passed emissions with swaping in a 3400 in older cars 2.8/3.1s. well it can be done. also i do not have an EGR at all.
    for anyone wondering, I used my 2.8 ECU and 2.8 INJECTORS. i used to run my 3400 injectors thinking it would help, and those were causing me to BOG and fail emissions really BAD. also slowing me down. car dose not seem to be running lean at all. i hooked my car up to a scaner to check.
    HC .3055 limit is .800 used to be 8.XXX ( with 3400 injectors)
    CO 3.0560 limit is 15.000 used to be in the 60.XXX( with 3400 injectors)
    NOx 1.6834 limit is 2.000 was about the same
    i cut it close on NOx but i still passed.
    so if your running 3400 injectors with no special chip i recommend using your stock injectors. unless you don't need emissons then your just lucky and i hate you. LOL . I own an 89 beretta but im sure this would work with all 2.8 or 3.1s i don't think 3100s have this problem.
    I hope i help somone out if they are having these same problems
    mike
    89 BerettaGT 3400 5spd
    60' 2.106 street tires
    Best ET 14.313@95.37 N/A
    Now Boosted
    14s@109 (poor tune still rich, poor driving skills, poor owner)
  • ikessky
    • 614
    Milwaukee has emissions? I live up in Northern WI and we don't have emissions.........
    • DEI37
      • Jan 2004
      • 516
      Yeah, no kidding...hoo-rah for no emissions!
      • Berettaspeed
        • Apr 2004
        • 109
        well milwaukee is south eastern wisconsin. and we have very strict emissions. but the point is some people may be running the 3400 injectors and are having the same problem i had. and my ET time and MPH improved because of this.
        15.22X@91MPH
        before
        15.249@89MPH
        not much but MPH improved alot
        Now Boosted
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          If you install a fan over ride you can run the cooling fan before and during the test to lower the engine temp. This will pull down the NOx numbers.
