DRTC
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    DRTC
    anyone have detailed instructions on installing the TCE DRTC? I know about the crank machine work, but that's all the info I have... main thing I need to know is how to use the two depth gauges that came with the timing set.
  • unchained01
    • Jan 2011
    • 388
    I am interested also
    Mine should be back from cryo this week
    • Z26-T
      • Apr 2008
      • 486
      I was a bit curious to what the other pieces were that came with it. Depth gauge sounds good. I forgot that I have to machine the crank.. Guess I won't just be pulling off the cover and swapping over to the DRTC :P.
      • mfuller
        Mr. Common Sense
        • Nov 2003
        • 374
        You have to turn down the snout on the crankshaft, and do some slight clearancing on the block behind the timing cover. I think you also have to ground down one of the oil galley plugs.
        Sent from my iPhone using Tapatalk
        Matt
        • mfuller
          Mr. Common Sense
          • Nov 2003
          • 374
          I forgot that you also have to do some slight clearancing on the backside of the timing cover itself.
          Matt
          • MY91GT(Z)
            • Sep 2006
            • 387
            3x00 modified has installed one of these in friends car have to ask him what needs to be done
              One is supposed to be a depth gauge and the other is a straight edge that should lay flush against that and the gasket face of the timing cover when you mill out the inside of the cover... I think... I have to have them in my hand again to verify that, I'll check when I get home.
              You can see where I clearanced this cover...
              And the crank mod, Compare to yours to see the difference.
              • ericjon262
                build it.
                • Jan 2010
                • 2218
                install instructions attached as a PDF
                  That's what it was!
                  I didn't think it made sense in my head for one to be a straight edge for the timing cover... lol
