3.1 MPFI rebuild
  • DEI37
    • Jan 2004
    • 516
    3.1 MPFI rebuild
    If I took a 190,000 mile old 3.1 MPFI, used a Crane 260 (?) cam...I'll take recommendations here...and bored it .030 over, using appropriate 3100 SFI pistons, and DID NOT make any modifications to the computer (would this work?), what kind of power could I expect to make? I might open up the airbox, remove the cat, and open up the exhaust a little. Not sure what exactly I'll do yet, as I have another project in the works that has to be done first.
    Thanks.
  • DEI37
    • Jan 2004
    • 516
    Anybody?
    • GPXSS
      • 588
      probably no more than 160hp. You get the increased compression, and a more aggresive cam, but you still have the restrictive 3.1 intake.
      I modify stuff
      • DEI37
        • Jan 2004
        • 516
        OK. When you say intake are you taking about between the airbox and the throttle body, or upper and lower intake manifolds?
          • 9191
          Upper and lower...
          • DEI37
            • Jan 2004
            • 516
            So basically, I'd want to swap in 3100 heads and up, correct? I ask, because in a short time, I anticipate having a 3100 sitting around...could I use that engine's heads, upper and lower intakes, then? It's in my '97 CS.
            • TheProfessor
              • 869
              you would be much better off using the heads and intake from a 2000+ 3100 or a 3400
              I Like V660s
              Does Chevy make beer
              ~Jayme~
              • DEI37
                • Jan 2004
                • 516
                Hmm. That's sucky...this engine's parts will be free...that's why I'd like to use 'em. It is starting to break up already internally. Had a good bottom end rattle develop tonight. Went away after a couple minutes, and hasn't come back, but that bottom end can't be ready for many more miles.
                • MasterJacko96
                  • Jan 2004
                  • 61
                  i know someone that wants to sell P&P old stule 3100 inttakes with a tb for $125 pm me if your intrested and i can give u his contact info with some pics
                  1996 Monte Carlo LS 3100 engine, 1/4 16.131 *RIP
                  88 cuttlass supreme 2.8L coupe
                  90 dodge daytona 3.0 v6
                  • MasterJacko96
                    • Jan 2004
                    • 61
                    however i would go with new style 3100 or 3400 intakes i swapped P&P new style intakes on and it made a huge difference even with my ailing tranny
