i have some dtc codes i need help with
  • Jeremy90
    • Nov 2012
    • 23
    p0004 fuel regulator control high
    p0420 catalyst system below threshold
    p0440 evap emissions control system error
    p1200 injector control circuit
    p2004 intake manifold runner control stuck open bank 1
    any help on what these mean and how i could possibly fix them? these have me horribly stumped so any help is appreciated
    these are all obd2 by them way off my 97 chevy lumina base with a 3100 sfi
  • Purple pit
    • Oct 2012
    • 718
    My guess is that the 0440 is for the purge valve. It is behind the coils and down about 1/2 a foot. Look for a little green cap.
    I have no clue what a intake manifold runner control is.
    Sounds like the fuel regulator has been letting too much gas go to the injectors and killed the converter.
    Grand Prix trans with 3.33FDR
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      P0420 is for the post-cat o2, it could be the cat, or the o2 sensor, but I think the PCM has logic to tell if it's the o2, or the cat, so my bet is the cat.
      IIRC P0440 could be caused by a worn, or loose gascap.
      what are you using to pull these codes? some of those sound way wrong for your car.
      • ericjon262
        build it.
        • Jan 2010
        • 2218
        as a follow up, I just checked a 2001 grand am bin, and I don't see half of those codes in the bin at all, much less turned on. I know it's a few years off, but I'd be willing to bet they aren't in yours either.
        • Jeremy90
          • Nov 2012
          • 23
          i used an elm usb to obd2 scanner and easy obd2 version 2.4.5 if you have any other free software i could use thats more accurate im open to suggestions also i used a chevy list for the obd2 codes although im not sure where it went to now
            As noted some of those codes aren't even specific to your car... so it's a bit odd that they would be showing up. Will a local auto parts store use their tool to read them for you?
            The Free ELM's are nice but they don't always work.
            • Jeremy90
              • Nov 2012
              • 23
              the elm reader wasnt free and i gotta see about getting it up to an auto parts store first its feeling like theres a grinding (not sure where) and loss of power is what its really doing to give me trouble it just feels very unstable but i am gonna see about getting it up to the auto parts store and checking it this week sometime i have to recharge the battery!
              by the way i appreciate all the expert help here guys!
              • TurboGTU
                • 453
                Get the Torque app. I got more consistant codes with that one.
                EDIT: Just saw you have USB and not BlueTooth. Your limited to the free Scantool.net file floating around.
                • Jeremy90
                  • Nov 2012
                  • 23
                  im actually not limited theres quite a few free obd2 reader programs out there
                    I meant the free software, not the unit itself.
                    • Jeremy90
                      • Nov 2012
                      • 23
                      ah okay i guess ill try the scantool.net software see how it goes
